I'm looking to find a more comfortable seat for my R33, as I'm really uncomfortable in my line ATM.
I'm 192cm and 100kg, and I've got wide shoulders.
The stock R33 GTS-t seat was pretty painful, b/c it would dig into my upper back, and it was way too high for me.
I've got a R33 GT-R seat now which is slightly better, as it sits lower and doesnt dig into my upper back, but it is way too narrow for me...
I was looking at a 300ZX (TT) seat, and it looks way more comfy.
Just wondering if anyone (larger guys mainly) have had any experience driving a 300ZX, and if it was comfy or not.
And does anyone know if a 300ZX TT drivers seat will fit into an R33 with little or no modification?
https://www.sau.com.au/forums/topic/161309-300zx-seat-in-skyline/
Id be just over 190 cm too, around early 90's kg and i was more than comfortable in my 33. Granted more knee room would have been good but i never really felt uncomfortable. I sat in the passanger seat of a 2 seater 300 and found it the same sort of fit, slightly more leg room tho. The only way im massively uncomfortable is if you got a 33 with a sunroof... then i got not chance of fitting in the car.
Whether the 300 seat will straight swap into the line or not, i cant help you
Edited by ctjet
As you can see from my dodgy paint pic, the points marked with the red arrows are the spots that dig into me because of my height, and width.
The seat backing is too short for me, and the base sits too high, and yes i do have a sunroof.
The 300ZX backing seems to flow like one long piece, and it doesn't look like there are any points that would dig into me.
i'm 182cm, 90kg. my GT-R seat is a little too narrow for me, but it is still liveable. my back doesn't actually fit, it feels like the side bolsters are digging into the outside of my lats.
it grips my body like buggery though, so i put up with it.
Why dont you take a 300 for a test spin from a dealer or importer and see how you go. its hrd to compare seats because it feels like your sitting A LOT lower to the ground in a 300... and laying down more slightly. But i know what your trying to say. Tried a 34 GT-t seat?
I cant belive your slightly taller than me and are not complaining about head room!!
Yeah, headroom (with a sunroof) is a real bitch with the standard seat, but the GT-R seat is low enough to give me *just* enough headroom.
I am 195cm, way over 100Kg and do not get any back problems in my 4dr, lack of thigh support is a different answer....
I am assuming that my 4dr seat is less agressively sporty than a 2dr and this would most likely explain my increased comfort. Apart from non-folding backrest, would one of these be an option for you?
Headroom was also a reason for choosing the 4dr over a 2dr in the first place. Framed windows make for a bigger whole for me to get my shoulders through....
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
