Sold Pending Payment
i have an Apexi Power Fc from my old car, i am selling my car and i am putting the stock computer in to sell it, so i have sell the power fc seperate.The power Fc came out of my 1995 R33 gtst and has been in the car for 1 year, it works fine. I am after $1000 with hand controller or $900 with out hand controller. Im located in the northen Teritory. I Prefer local pick up but will consider postage. PM For more Info or Pics....
Cheers paul
Edited by paulcosta
  • 3 weeks later...
ATTENTION: THIS GUY IS A SCAMMER I HAVE CONFIRMED IT WITH A FELLOW FORUM MEMBER RESTLESS33..
He was trying to sell to me and restless33, though I did catch him out when he gave me a false name for his account details. I then played a little game with him and he ended up hanging up on me and not returning my pms..
I hope not to many people got ripped by him..i will send an email to skylines australia..and pm a moderator.
Cheers Daniel
Guest
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
