  • Replies 41
These arnt drift teks dude.. They arnt made in 18" i also found this out .. so what are they?
They are Rota P45R's, i know this because i was going to import some from the usa a while ago, some people in the uk also call them Rota GTR's, if you do a search on google for both of these names you will find pics of the exact same wheels and most of the colours they are avaliable in.
is it just me or is the first pic of all the diff colourd wheels diff to the rest of the pictures? i want 18's in black so someone buy my starcorp's!
Yip the pic of all the different coloured wheels are not the wheels that are for sale on this group buy, they are another "copy wheel" they are copied from a wheel called "desmond regamasters".
Hey FOBS15 I am thinking of getting them for my S15 as well. What size are you getting? I have stock guards front and rears are lipped.
Im thinking
18 x 8.5 ET25 offset front
18 x 8.5 ET30 offset rear
should be flush with guards and clear coilovers.
Not sure 18 x 8.5 ET30 offset would clear coils at the front and that 18 x 9.5 ET30 offset would fit in the rears
Edited by Paragon
Im thinking
I am planning to get 18 x 8.5 +30 all round. Should fit nice. If they were 9.5 on the fronts then they'd def hit the coilovers.
FOBS15: You still have not updated your first post as requested.
I will check again at the end of the afternoon and if the supplier details have not been included, this thread will be removed.
if this groupbuys still going, i'll be in for black 18x8.5 30 X4, how much was it with tyres included?
Sorry this GB is only for the whells alone. Might organise a GB for tyres. See how this goes first.
I need to know if these will 100% fit an R33 GTSt, anyone have confirmation on offset? If so then i should be in for a set of bronze 18's.
This also depends on the width ur goin for. Offset if im not mistaken is +30 on those Skylines, correct me if im wrong please as im into my silvia's.
Also pplz please remember that the spoke profile is different on less wider wheels. Pics are showing a 9.5 inch wide wheel. Spoke profile is different on smaller width wheels. I will try get a hold of some pics and post so u get an idea of what im talkin about.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
