subzeroR33 Posted March 21, 2007 Share Posted March 21, 2007 (edited) Hi all. Looks like my coils have shit themselves and im looking at buying some splitfires. My current set up is a microtech Ltx-12 and a MSD 4 ignition with a Ford coil pack on a series 2 RB 25DET. Yes i know its Ford, but they are going. Do i just order the series 2 split fires or something different with the set up i have. Oh and what is the expected price to pay, ive been told around $600 mark. Cheers. Edited March 21, 2007 by subzeroR33 Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/ Share on other sites More sharing options...
Craved Posted March 21, 2007 Share Posted March 21, 2007 the split fires are direct replacement for the std coils... soo S2 run the ignitor in the coil pack itself .. is this how your ford ones run? i wouldnt think so with the MSD 4 here are pretty much teh cheapest in Aus you can get the splitfires for that i know http://www.skylinesaustralia.com/forums/in...howtopic=153971 Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/#findComment-2996561 Share on other sites More sharing options...
subzeroR33 Posted March 22, 2007 Author Share Posted March 22, 2007 the split fires are direct replacement for the std coils...soo S2 run the ignitor in the coil pack itself .. is this how your ford ones run? i wouldnt think so with the MSD 4 here are pretty much teh cheapest in Aus you can get the splitfires for that i know http://www.skylinesaustralia.com/forums/in...howtopic=153971 Yeah im not sure if i can run the split fires with the set up i have, maybe someone knows. Thanks for the link Craved. Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/#findComment-2998019 Share on other sites More sharing options...
Sydneykid Posted March 22, 2007 Share Posted March 22, 2007 From memory, the Microtech LT12 has the ignitors (6 of them) built in and so on a 6 cylinder it can run full sequential ignition. The term "MSD4" is bit generic, you will need to be more specific. For example, if it is a MSD DIS-4 HO then the Microtech ignitors are being used to fire in wasted spark mode, so you should have one ignition circuit in the MSD not being used. Check that with your mechanic and/or tuner. Personally I would have run 1 x MSD DIS-4 HO and 1 x MSD DIS-2 HO so that I could run full sequential ignition. Regardless, if the above is in fact the case, then you need R32GTR/GTST style Splitfires, ones that don’t have built in ignitors. Keep in mind that even with 6 Splitfire coils, you will still have to run wasted spark, as you only have 4 (3 used & 1 not used) ignition circuits in the single MSD DIS-4 HO. cheers Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/#findComment-2998765 Share on other sites More sharing options...
subzeroR33 Posted March 22, 2007 Author Share Posted March 22, 2007 From memory, the Microtech LT12 has the ignitors (6 of them) built in and so on a 6 cylinder it can run full sequential ignition.The term "MSD4" is bit generic, you will need to be more specific. For example, if it is a MSD DIS-4 HO then the Microtech ignitors are being used to fire in wasted spark mode, so you should have one ignition circuit in the MSD not being used. Check that with your mechanic and/or tuner. Personally I would have run 1 x MSD DIS-4 HO and 1 x MSD DIS-2 HO so that I could run full sequential ignition. Regardless, if the above is in fact the case, then you need R32GTR/GTST style Splitfires, ones that don’t have built in ignitors. Keep in mind that even with 6 Splitfire coils, you will still have to run wasted spark, as you only have 4 (3 used & 1 not used) ignition circuits in the single MSD DIS-4 HO. cheers cheers It is a MSD DIS 4. Yes the microtech does have the inbuilt ignitors. Thats what i was wondering what type to get with or without inbuilt ignitors. Thanks for ur help mate. Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/#findComment-2998905 Share on other sites More sharing options...
prego Posted March 22, 2007 Share Posted March 22, 2007 keep me updated on this i hope its the right answer for your problem Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/#findComment-2999167 Share on other sites More sharing options...
subzeroR33 Posted March 22, 2007 Author Share Posted March 22, 2007 keep me updated on this i hope its the right answer for your problem Yeah mate will find out on Monday. Hope its not to serious. Link to comment https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/#findComment-2999220 Share on other sites More sharing options...
