Hey people,
Loved skylines for a very long time, and now I'm finally the proud owner of a black r33 gtst.
I've got a gtr front bar (fake) on it. The original indicators/foggies are gone, and the cable to them has been cut. I got some custom indicators done which look great, but they were LEDs so the auto-elec put in some sort of regulator to keep the clicking at normal pace (it was spastically fast due to missing lights - LEDs dont draw current so they didn't return it to normal).
everythings great, except for one thing. Theres a delay from when i push the indicator to when it starts clicking. its about 1 second. now this doesn't seem much, but when i'm weaving in and out of traffic it feels like an eternity, and is potentially quite dangerous.
I'm guessing the delay is from the capacitors in the installed regulator. So i wanna get normal incandescent light globes for my flashers to replace the LED in the flasher and remove that regulator. only problem is, unless i get globes with the same resistance as the original skyline indicators, the timing won't be right. is this correct?
so to my question, has anyone had to change globes for their front indicators on a series 2 r33? would your normal globes from autobarn/supercheap be right? or were the skyline globes extra special? reason i'm asking is the s2 lights look pretty big so they might have had a bigger globe with different resistance etc.
thanks for any input!
p.s. i know some of u might be thinkin "what a retard! they're just indicators!!" but i'm REALLY fussy with this sorta stuff. unless its perfect it will drive me CRAZY.
https://www.sau.com.au/forums/topic/161371-indicator-resistance/
I don't think u're crazy u are actually quite sensible cause like u say weaving in and out of traffic or just having to change lanes quickly with that sort of delay could cause accidents and chaos.
hey dude im an auto electrician. just replace your flasher unit with an electronic bosch 1 by memory their like $15. they dont rely on load so you can get rid of the resistors that sparky put in. used em on heaps of cars with l.e.d indicators and they work great. and take 2 seconds to change. they are only 2 pin (not 3 pin like the standard 1) it doesnt need the 3rd wire its just an earth.
and other questions just pm me?
that's what's in there now. only its not a bosche, its a "navar" (i think that's the spelling).
whether i put in led globes, or filament globes the clicking pace stays the same, and there's still a short delay from when i push the indicator stalk to when it starts flashing.
  • 1 month later...
sorry to dig up an old thread... i have the same problem except i got a new front bar and have new indicators to go with it and they are flashng to fast... i also found that if the earth and positive are touching it makes all 6 indicators go off when you use one direction.
i can get them to work normally eg. down each side like they should but they are flashing way to fast... any ideas. also where is this flasher unit and any idea hat the part number is for the boche unit
thank, Mark
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
