Hey Guys,
I have tried searching and have found a few little bits and peices but its not exactly definitive or what im after.
Ok basically i am going to be starting a project with a R34 Coupe or 4 door (not sure yet). Seeing as the non turbo models are a fair bit cheaper i have been looking inot buying one of those as a base. But then i got thinking about differences between the 2 different variants.
Basically im after the major differences between the 2 ie brakes, suspension, chassis, anything that is performance inhibiting or is something else that will need to be upgraded if i was to buy a non turbo version.
I relise there are series 1 and 2's i have found a bit of imfromation on these so you need not post up about that.
The car will eventually get a different engine so the fact that one is turbo and the other isnt want be a problem.
Thanks in advance,
Neil
when you say its going to eventually be another engine in the car..
are you talking about some thing other than a rb25neo ???
if you are going to upgrade the engine to a turbo'd rb25 in the long run anyway, dont waste your time getting a N/A in the first place IMHO
Eventually it will either have a rb25 with 30 bottom end or a 2jz, however this is still undecided. Either the turbo or non turbo head will work with the 30 block so it doesnt particularly matter which version i buy in that view.
Neil
The interior is slightly different, the R34 N/A lacks the three gauges that the turbo model has.
Im pretty sure the N/A model has smaller brakes.
Not sure about suspension differences.
Chasis is the same.
Neil
ah ok, fair enough. Just wanted to make sure it wasnt a.. "buying the NA skyline cos I cant afford turbod now, and will drop in a stock turbod engine later" type project :pirate:
as said if u go for a gtv model you will get everything the turbo model has minus the turbo. that includes suspension, brakes the works. there is some food for thought.
Edited by smurf80
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
