Good upgrade would be R32 GTR which are 16mm bigger
in dia and 2mm thicker along with braided brake lines and
good brake fluid and good brake pads.I would recommend
sloted rotors they have more bite do not get cross drilled
as they crack.Or I have heard that R33 GTS fronts are
also a suitable upgrade.The good thing about this upgrade
is that it's cheap and efective and still fit 16inch rims.
yeah, 32 GTR would be the go. they are cheap enough as lots of GTR owners go for bigger brakes. they run a 296mmX32mm front rotor vs the 280X30 you have now, and the rears are 297mm so maybe do all 4 at once.
Quote me if I'm wrong but I think the rear brakes are they same on
GTR-GTS (GTR non Vspec)
Nothing wrong with standard M Spec brakes for track days, as long as they are in good condition. The usual
Replace the standard rubber hoses with braided
Service the callipers
DBA 4000 series slotted rotors front (4909) and rear (4908)
Castrol Super Response Dot 4 brake fluid
Hawke Black or (if you have ABS) Hawke Blue MT 4 compound pads
:pirate: cheers :)
:) cheers :(
wouldn't u be better off buying new DBA 'gtr' slotted rotors if your going to buy new ones? Surely the price would be similair!
