I wanna do "some" internal work to the value of about $3000 (incl labour) if i do forged pistons, do i need to do the rods too or is that not necessary? Is there another option to forgies? I read once in a mag that there was another option which is better on cold start than forgies are. How much would i be looking at for pistons and which brand would be a better option, for just a street car with occasional track outings and sometimes running the 1/4
Any help, advice or websites will be much appreciated.
ta
https://www.sau.com.au/forums/topic/161431-pistons/
So, you have told us absolutely nothing about your cars modifications, or what type of engine you are planning on doing this too.
Your budget is completely unrealistic for what is effectively an engine rebuild - Pistons/rings alone will chew at least half your budget, and good luck finding a quality workshop that will do engine r & r, full disassembly, machine work and reassembly for ~$1500!
A good set of forged pistons with rings will cost anywhere from ~$1200 or so up to $3,000 depending on what you want. Common reputable brands such as CP or ACL would probably be the best for you.
Bottom line, if you want to rebuild your engine with 'forgies' and you want to do it right, be prepared to set aside $10k including parts.
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-2998158
my rb25 acls with rings and gudgeon pins was under 1k delivered. Your rebuild will be purely based on your power goal. No need to put in whats not required.
Other option your thinking of is hypertek pistons i believe.
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-2999553
oopz sorry, its an rb25 all i want from it is around 270 - 300 rwkw, but im in no rush, i also have seen some cast pistons which may well do the job as they are 40% stronger than standard items... (any comments?) oh ive got alot more than 3K ready for it, but like i said id rather do it slowly also i cant do without a car for long, so i was thinking pistons first with a set of gtr rods if i can do that (cryogenically treated to strengthen it) if i do pistons do i have to do the rods too?
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-2999729
If you do pistons you dont have to do rods, thats optional, You can get your old ones race preped so to speak, and will handle you power goal fine if you do, If you want to over exceed that get rods, as this will save having to open the engine up again. hpe that answers your question, and as the others have stated, unless your doing the work yourself 3k is not enough far from enough
Piston Bores require a hone/bore for oversized pistons rings, and machine work for block plus your head work been best to get a full service done to it is anywhere from 1300 - 2k For the above
Pistons another 1300
Then you have to include labour, bearings, Gaskets, Water/oil pumps, Belts, Oil, Coolant, Theres the good part of 3k upwards
Ummm hope they answer your enquiries
Cheers
A
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-2999751
man its unbelievable how much people get charged to get stuff done....i rebuilt my whole rb25 with forged pistons 20 thou over, new bearings all throughout, recod head with new stem seals and cut the valves and seats, decked block, new welsch plugs and faced the head and i did pretty well most of it myself except the machining, oh a cometic mls gasket as well...i think i spent max 3k that included a few new lines and hoses. Was pissed that they didnt reassemble the head...i had to lap the valves in myself and reassemble it....and i lost a collet in the process.
Workshop manual and a little time and you can save alot of money. However i wouldnt recommend it if your not confident in your mechanical ability.
For the power output your looking at mate...all you need is what i did. Probably not even that. Dont waste your time on rods, if your going for 400rwhp, maybe put some arp studs or bolts in them, unless you can find a cheap set of gtr rods.
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-2999762
like i said guys if i dont have to get forgies to achieve 300rwkw i wont get them, but just for piece of mind id like to get something stronger than factory ive seen cast items which are 30% stronger than factory ones anyone used these? anyone with any experiece with these gimme some comments ta
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-3003025
as far as im aware (rebuilt my rb25 2 weeks ago) i couldnt find anyone in aus who sold a STD rb25det cast piston..only pistons available were forged.. 300rwkw or 200rwkw if u get bad detonation ur going to blow a piston wether its cast or forged...
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-3003080
dont get cast get forged.....there only like 1100 bucks so no that expensive if you wanna go big later. But the thing i found with my rebuild that all the little crap like head gasket, gasket kit, bearings, timing belt, idler/pulley, water pump tensioners and all the little bits and pieces you made need here and there all cost you money. like with my gf wrx were rebuilding now found out the clutch was stuffed aswell so theres at least another 500 on my rebuild for that.
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-3003430
ppl like me pay for it cos I dont have any time to spent building engines.. my mechanic does that.
However looks the good from what you have done. What sort of power are r u running?
https://www.sau.com.au/forums/topic/161431-pistons/#findComment-3003566
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
