Hey guys, currently only have a stockie '96 R33 S2 M-Spec but having gone from a 98 Honda Accord immediately felt the power difference in every aspect. Now after only a month im used to it and it just feels like any old car...time for upgrades i think :pirate: first was thinking of turbo back exhaust, if done right apparently you can pick up anywhere in between 20-30rkws! This would make a significant improvement and secondly FMIC.
What are your opinions? Thanks in advance!
https://www.sau.com.au/forums/topic/161436-more-power/
you have the right mod first, plenty of power is gained from a good exhaust. i went from 144 to 169rwkw with a split dump pipe, 3" system and 5" cat. thats your best option to start with. them fmic and boost, then next level ecu, injectors, pump, turbo, clutch etc etc...
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-2998170
yeh when i had 254 before i blew it up it felt slow....but now 12months later 200kw @6psi lol feels fast but getting tuned for 18 next week....make sure you do your mods in stages so that you get the feel for the car at each power level, i know dudes that went bang heres 15k on mods 12 months later there bored again. rather than do it slow and have more fun
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-2998896
Watch out for the power bug LOL
I went from 199rwk's to 260 and then 292rw's. Now that even feels slow, until you line up a crapy comodore. LOL
As a few of the guy's said before though, the more often you drive it , the less spectacular it feels.
I ownly drive my GTR 1-2 times a week now and get more pleasure from driving it . Damm beats the 1.6 laser wagon. LOL
8 months of withdrawal though waiting for the new clutch. Now its back on the road , Im in heaven. :(
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-3001009
Im now sick of 382rwkw that ive only had for 1 week, but have been driving it a fair bit.
As mentioned the less you drive your car the better it feels.
not bragging ae we?
i agree that above 300 is great but i wouldnt say im sick of it! thats a big call...
where can you use it?
if its a street car then 300 - 350 is ample and can / will get you into alot of trouble with the po po!!
just my thoughts...
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-3002030
Keep in mind the other alternative to make it fun is to make it perform better overall e.g not just more speed but better handling and stopping as well. Great to go fast in a straight line but feeling what it can do through the twisties is a great rush as well.
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-3002037
mines only got 230 @ the wheels but cause i only drive it a couple of times a month it always feels fast!
yah same...lucky if i get once a week
damn sick of 382kw?
i dont think its the power u're sick of...its the car :)
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-3002762
not bragging ae we?
just my thoughts...
Where i live there is plenty of space to use it.
Ok, maybe not sick of it, ive driven my car so much this week im "used" to the power it has and want MORE. Think im greedy.... But dont we all want more all the time.
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-3002790
you young man have to take me for a drive in your car.
Im sick of my stock 20det and want more power.
I think you might scare the crap out of me in ur car.
https://www.sau.com.au/forums/topic/161436-more-power/#findComment-3003067
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
