Hey Guys,
I have a little problem. My front drivers side swaybar mount on the back of the wheel hub is broken clean off!!!! :pirate: WFT!!!!! :)
I have a whiteline blade adjustable swaybar with the heavy duty link kit and the kit is set to the third hole from the end of the swaybar.
Has this happened to anyone else?
I have ran both the blade adjustable front and rear bars for about a year and the Super Low King Springs for about 8 months without any issues...until now. Can this be replaced without having to replace the whole hub? Annyone?!
Nate
Hey Guys,
Nate
Happens occasionally, just weld the bracket back on.
:huh: cheers :D
So this is attached to the wheel hub and not a replacable item? So I should be able to just weld it and it will be fine?
Yep, I added some gusseting to mine, so it didn’t break again. Being a 100% race car, mine has a 27 mm front bar, spherical joints on the links and relatively soft spring rates, so it loads up the standard brackets a fair bit.
:pirate: cheers :)
:) cheers :huh:
Thanks for your help. :pirate: Now I have to hunt down a friend with a welder!
  • 12 years later...
Yes you can, I used to snap these every few track days.
I suggest running better suspension and reducing the hardness of your ARB.
I was all in for the super thick, super stiff ARBs but now have both on the softest setting however run much higher spring rates to combat body roll, pitch and also getting much better lap times.
Thanks for all that. Sounds sensible.
I might swap back to the stock sway bar for now.
Just had a brake problem, has anyone replaced this bit of hard line. Do I just take it off and get someone to pipe bend up something similar?
I think the stray sway bar link may have contacted the brake line while it’s been disconnected ..
Not only is the pedal feel worth whatever you have to pay, but you also get to get rid of 20+ year old rubber lines that are probably unsafe anyway.
But, here's the hot tip.....https://www.ebay.com.au/itm/HEL-Braided-BRAKE-Lines-Nissan-Skyline-R33-GTS-T-GTST/271573448661?hash=item3f3b09f7d5:g:1AEAAOSw-ldZaG1u
The original, and still the best.
The do have a plastic sleeve. Your choice of colour, etc etc. And they mount properly - they have the blocks needed.
I'm not recommending against GK-Tech - I use lots of their stuff. But the HEL lines are noticeably cheaper - and up until Dose sent me a picture of one that was very questionable, I had never had cause to doubt their quality. They were the first to offer ADR approved braided lines, after all.
But at least it is possible to tell if they (or any other brand) have been crimped, now that you know to look!
You can see and feel if a crimp has or hasn't been done. And if you pull really hard on the ends, they might come off if they're not crimped.
I wouldn't be too worried about such lines not getting crimped. That would have to be an exceedingly rare failure.
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
