A few points to consider,
- if it is reply to an advert answer all points written in the ad
- Try to set yourself apart from the rest, generally if you are applying you have the skills they are looking for, but show what you will bring with these skills.
Typical layout would be something like
Intro Para - I wish to apply for this job ________. I am ________
2nd Paragraph - discuss how you meet the key criteria that they require
3rd paragraph - Other points
Final - Thanks I'm Keen, please contact me on _____ and if you have any questions.
Regards, ____
https://www.sau.com.au/forums/topic/161459-cover-letter/#findComment-2999588
the cover letter is the most important part of the application. It is where your potential employer uses the cover letters to distinguish between the crap and the good applicants. Your aim is to tell them why they should continue to read your resume over others. If your cover letter is a good one then you will most prolli get chosen to go ahead further. Like L3nny states above, you dont want to ramble on irrelevant points. The main aim is to focus on the requirements that are proposed in the advert. Stick to highlight those aims and make it intersting, dont babble..you dont want to bore them.....Lastly, make sure you have flow and is not rushed as though an employer can deffinately tell between a well thought letter and a rushed one. Good Luck.
BB >_<
Edited by boostd_r32_gurl
https://www.sau.com.au/forums/topic/161459-cover-letter/#findComment-3001239
make sure you triple check your spelling and grammar in the cover letter!
you wouldn't wanna f**k up there.. and i know you adelaidians aren't too good with your English.
and i'd say no more than 3/4 of a page.. anything more htan that, they'll lose interested (as the guy above said)
https://www.sau.com.au/forums/topic/161459-cover-letter/#findComment-3001313
Nice points about checking spelling. U might want to check you own spelling before calling us stupid at the same time as well...now <edit/ go> back to your hole and use a dictionary...
**my post is intended to offend so if u dont like it -
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/161459-cover-letter/#findComment-3001496
Are Engrish & grammer is just fine Liz :wave:
You might be surprised to know South Aust'ns actually has the bestest proper English speak in the nation....arrrh! >_<
https://www.sau.com.au/forums/topic/161459-cover-letter/#findComment-3001521
Regards, ____
awesome thanks L3nny :wave:
BB :kiss:
thanks for the info, should be fun trying to make it interesting :glare:
my spelling, english and most of my grammer is fine :kiss::P
but nah i will check it just to make sure
https://www.sau.com.au/forums/topic/161459-cover-letter/#findComment-3002139
    • -9s are discontinued supposedly. But you can still get Nismo R3 turbos which are something like a -7 but subtly different? -7s are also available. HKS GTIII-SS and GTIII-2530 are also available but they're journal bearing MHI turbos.
    • Late to this party but here is your go to shop in perth - https://www.facebook.com/gsautoworksau GTSBOY is on the money cost wise, drive in and out will cost you 15-30k or more.    Some items that will save you money  - plug in link ecu g4x is much cheaper than haltech.   -Pulsar turbo, seem to be "OK" now, never used one myself You really don't have to build the motor, E85, headgasket, studs and a good RB26 will live for ever.    Swapping over the twins won't save much as you still need ecu, tune, fuel system etc.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
