Cover Letter
pokie
 Share
okies so i need some help with this whole cover letter bisso.
never done 1 b4 so if some1 can tell me what i need to put in
a cover letter then that would be awesome.
A few points to consider,
- if it is reply to an advert answer all points written in the ad
- Try to set yourself apart from the rest, generally if you are applying you have the skills they are looking for, but show what you will bring with these skills.
Typical layout would be something like
Intro Para - I wish to apply for this job ________. I am ________
2nd Paragraph - discuss how you meet the key criteria that they require
3rd paragraph - Other points
Final - Thanks I'm Keen, please contact me on _____ and if you have any questions.
Regards, ____
the cover letter is the most important part of the application. It is where your potential employer uses the cover letters to distinguish between the crap and the good applicants. Your aim is to tell them why they should continue to read your resume over others. If your cover letter is a good one then you will most prolli get chosen to go ahead further. Like L3nny states above, you dont want to ramble on irrelevant points. The main aim is to focus on the requirements that are proposed in the advert. Stick to highlight those aims and make it intersting, dont babble..you dont want to bore them.....Lastly, make sure you have flow and is not rushed as though an employer can deffinately tell between a well thought letter and a rushed one. Good Luck.
BB >_<
Edited by boostd_r32_gurl
make sure you triple check your spelling and grammar in the cover letter!
you wouldn't wanna f**k up there.. and i know you adelaidians aren't too good with your English.
and i'd say no more than 3/4 of a page.. anything more htan that, they'll lose interested (as the guy above said)
Nice points about checking spelling. U might want to check you own spelling before calling us stupid at the same time as well...now <edit/ go> back to your hole and use a dictionary...
**my post is intended to offend so if u dont like it -
Edited by Bl4cK32
Are Engrish & grammer is just fine Liz :wave:
You might be surprised to know South Aust'ns actually has the bestest proper English speak in the nation....arrrh! >_<
Regards, ____
awesome thanks L3nny :wave:
BB :kiss:
thanks for the info, should be fun trying to make it interesting :glare:
my spelling, english and most of my grammer is fine :kiss::P
but nah i will check it just to make sure
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
