Adapter was fitted(but need to check if is 1521500) and in addition my tuner also put in resistors for the coils.
it should not need those resistors. only the old emange used external resistors in a module.
keep me updated.
  • Replies 765
keep me updated.
This morning changed setting to 12v start the car drove off and stopped after abt 2km parked the car at 10am. Came back to start car 1.30pm, cudnt start after several tries and half hour later. Got the car towed to workshop to test electricals:
1. Change back to 5v, still cannot start
2. Took out cam angle sensor, spin it and check with ohm meter and oscilloscope
3. Fuel injectors signals ok
4. One coil/spark out of head, check no sparking
5. Ignition input signals ok
6. Ignition output signals not detected
7. Swap to another ultimate board - still the same no sparking
8. Disconnect ultimate and using stock ecu - still no sparking
9. Open up stock ecu - motherboard looks ok with no smell of burning
Suspect stock ecu affected so meantime sourcing for another stock ecu to test or cud it be the cam angle sensor but the injectors signals functioning. My tuner said the ultimate installed is the latest version using the 'E' board which allegedly does not require any ignition adapter. The adapter is a mini-board attached just above jumpers J7 & J8 and this to get rid of the engine check light. Is there another additional adapter making a total of 2 adapters required as I saw on the Nengun website Adapter 1 & 2 are needed for ER34 engines.
So is my stock ecu or its ignition circuit fried? What's the mechanics of setting to 12v when the coils are rated 5v and did this setting send back any rogue currents to affect stock ecu? Is there any set parameters made up by the makers Trust?
Appreciate any help and advice
Edited by docang
E board still requires internal mini board adapter. you should only need one mini board adapter...
This adapter came together with the ultimate board order and was fitted onto motherboard when initially installed in my car.
I can try to get a picture of the motherboard and post here tomorrow.
As for the 5v to 12v setting is there any advice from maker to set it so or any mechanics behind this?
i bought the two adapters recommended by nengun aswell as the one from USA (mohdparts)
these are the ones recommended by Nengun
and my understanding is that they were for the blue version and are carrying over on the nengun site
they are the little black boxes that wire in
seven wires (6 yellow ,1 black)
the other adapter that nengun recommend has only five wires(4 yellow and 1 black) this one im lead to believe is for Evos
this is the adapter that goes inside the EMU
but on that note ill wait to see what your outcome is before i reinstall mine
According to my local tuner my ultimate's the latest version 'E' board and only reqir the 2nd adapter which was duly installed as shown in ur pics.
At first when ultimate was installed and tuned on dyno with setting at 5v, 3 splitfires were burnt and this was allegedly due to boost/rev cuts generating heat during tuning for both afm and map sensor maps.
Car's auto and dynoed at crank: 390 din hp and 55.1kgm with the autotrans slipping.
So the issue with car not be able to ignite is whether my stock ecu kaput or ignition circuit fried or cam angle sensor wayward and now waiting to source for another stock ecu to find out and still awaiting a clearer picture of the 5v to 12v settings from Trent...
dyno1.pdf
Edited by docang
if you installed adapter #2 then that may be your problem
My understanding is that is for a 4 cylinder hence the 4 yellow wires for the ignition
maybe trent can clear that up
but if its burning out splitfire coils then there is something more sinister going on id say
Sori for the mixup, the adapter that was fixed up is the mini-board clipped onto the motherboard. As for the splitfires apparently the silicone cladding cannot withstand the hotter temps generated under boost/rev cuts conditns and stock ones fared better. The splitfires composite material melt on the top part just below the connectors.
Both the stock coils and splitfires were rated at 5v and my tuner was apprehensive abt changing the setting to 12v and wanted me to indemnify him in this instance...
Burning out coils is the lesser consequence than a fried ecu....
well for starters its an Output voltage change not an input
so it shouldnt in theory effect the ecu
if anything it will effect the coilpacks themselves
but please keep me posted on this im very interested to see what the problem is/was
THOSE ARE FOR THE BLUE EMANAGE ONLY.
the internal one below is the correct R34 Gtt and stagea adapter. ALL ULTIMATE ADAPTERS HAVE ULTIMATE CLEARLY WRITTEN ON THE BOX
Edited by URAS
the internal one is the correct R34 Gtt and stagea adapter.
Once the non-starting issue is resolved the setting wl revert back to factory of 5v....
Edited by docang
keep me updated.
Hi Trent,
Got the car started as it turned out the wiring to CAS was shot and got the wireman to trace the break and repair. Gone back to factory setting of 5v and initially after starting a bit of misfiring but went off after warming up. Currently have 5 stock coils and 1 splitfire on and the splitfire is starting to melt. The plug cover is off the engine to aid cooling. Wl try to source for a stock coil to replace.
So did the setting has an effect on the splitfire and misfiring and appreciate if you could provide a reasoning for the 12v setting to convince my tuner to change it.
Some problems cropped up with the ultimate:
- there is a fuel cut when boost hit 0.9 bar on half throttle and when my tuner tried to connect a boost cut defender to the
map sensor wiring the car cant start. Had a FCon S previously and boost cut was not a problem then hitting 1.4 bar and
my tuner who used to tune SZ is now looking into the S for some guidance. Hope u can help me out there...
- upon lift off throttle on boost and braking at low speed the rpm dropped and almost stalled. Shift to neutral and rpm rises.
With the S same problem but was helped by EIDS and when tried to connect EIDS to ultimate's AFM wiring there was
misfirings so appreciate your advice on any solution to this.
Engine mods:
er34 gtt auto
gt-rs
greddy 2bar map sensor with stock AFM
550cc sti injectors
hks fuel rail
hks 250l/h pump
hks 1.2mm head gasket
sard fuel regulator
hks fmic and pod filter
greddy rs bov plump back
low compression on no. 2 cyl (120psi and rest 140-160psi)
Mileage abt 300k and engine complete overhaul at 220k
Appreciate your advice.
Hi Trent,
Engine mods:
er34 gtt auto
gt-rs
550cc sti injectors
hks fuel rail
hks 250l/h pump
sard fuel regulator
I would find a new tuner fo the following reasons:
EMANAGE ULTIMATE has idle stability built in so no need for EIDS
EMANAGE ULTIMATE has fuel cut defencer built in so no need for HKS FCD
I think your on the money train.......
There is a dearth of good tuners in Spore and the one i've is one of the better ones... Only lately the local tuning scene has been using the ultimate and seems its more easier with the evos, rexes and legacies(liberties) here....
We've tried the boost cut limiter cut setting from 2 to 5v and it doesnt seem to work so tat's why tried to connect FCD to map sensor wiring. Is it ok to connect fcd to AFM wiring instead?
Wl try sorting out the anti engine stalling setting feature of the ultimate and as your screen shot shows the same for the boost cut limit setting panel, any shortcut help wud be most appreciated.
As for the 12v setting any explanation for changing to this from factory 5v is most welcomed.
Thanks in advance.
Just had a quick brouse of this thread after some time offline, and just want to ask if these coilpack voltages are applicable to my S2 R33 auto?
I have the Ultimate with plugin Loom..Is this all I need to get it running or do I need one of these Minibox thingo's??
Not real good at the electronics side of these things!!!!!!
Cheers Dave
Currently in Spore left only less than 15 Gtts and mine's the only one on ultimate.
Was paln to install an EMU to my Gtt auto ..need to study any problem that come while installing and tuning..
So what happen to other Gtt in s'pore..malaysian Gtt start to grow..
With our tax structure most Gtts went downunder & one even gone to S.Africa!
Msia sure hv more Gtts now than Spore. Last year i've gone for mitup with ur skyline kakis during JGTC...
Edited by docang
slightly off topic but can any1 tell me what sort of performance a lap top requires to run the EMU software?
I'm lookin to buy a EMU soon and was gonna grab an old 2nd hand laptop purely for tuning as i have to much other stuff on my current laptop.
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
