Who has dyno print outs to support these claims, id like to see some concrete evidence.
If you have them post them up.
i have the GTR proof that shows it is just as capable. i wont go as far as saying one is better than the other because i do both and both do the job admirably.... what i dont accept is people rubbishing the EMU and making rash statements that it wont match PFC.... cause i see it it match pfc all day everyday. Proof in the pudding is greddys 1000ps emu powered GTR.
  • Replies 765
Mt Isa ???
Geez mate who out there has been swayed away from Power FC
But yeah Ill take you up on that offer for sure
Do you have any idea as to when you may be heading up as it is already almost later in the year
Ive still gotta get my injectors and Poncams before the tuning starts
but if you head up before the poncams then so be ill tune without them
And a MAP sensor=)
Are there inputs so I can get signal from afr and egt etc?
Can I shange the boost with it?
Are the original knock sensor good?
how much do greddy map sensors cost? assuming they don't come with the 'kits' supplied by Slide?
to get the afr you need the afr adapter kit, but that also means you need a wideband o2 sensor.
hang on what's afr adapter kit and when do you need it? + wideband o2 sensor!?? sheesh, maybe this whole affair isn't really cheaper than a power fc
meaning ur able to use a wideband too see if the car is lean or rich. the adapoter ables to read from the wideband o2 to do data loging. the innovate ones are bout 600 i think???
does anyone know what settings to use to get a signal off the knock sensor?
what board is yours (little letter on the top of the circuit board) is it (d) (e) etc? only the later boards have knock display.
you need the same thing to tune a PFC..... if you not tuning it dont bother as you tuner has one.
mine had an (E) on it.
sweet and is the serial over 4500? if so all you need to do is use the settings in that RB26 file i sent you as it is perfect for RB's :P non-resonant (7.02 kHz)
whats 'over 4500' mean? where do i find out?
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
