E-manage Ultimate (emu) 56k Beware (screen Shots)
STATUS
  • Replies 765
Had a fair crack at fixing the ignition and fuel maps this morning.
Adjusted the scale on the A/F target, Ignition, and INJ1 to:
Start at 4000 rpm and finish at 7200 for rpm's
Start at 3.0V and finish at 5.0V for input voltage.
Still got a fuzzy bit in the ignition timing around 6000 rpm's where the timing goes from + to - with only one row of 0's seperating them.
Might have to space it out a bit further apart with the scale changer.
Heres a pic of my new datalog:
Still some work to do, but the AFR's are looking really nice now. Power delivery is very much improved.
nearly_fixed.doc
Could you please tell me exactly what was swapped around to fix the miss you said you had on your injectors UCD15R33?
You said someone changed 1 and 6 around? You mean removed and swapped injectors around or whats the go?
Just curious what fixed it for you because I had a severe miss with one of the injectors I was using.
Hello
I want to install the e-manage ultimate in my r33 gts25t spec 2 -97
What do I need more than this ?
https://www.rhdjapan.com/jdm/TRUST-E-Manage...c-Harness-24517
for ecr33
and the Ecu https://www.rhdjapan.com/jdm/TRUST-E-Manage...Main-Unit-18517
Does I need any moore parts ?
Is it just bolt on and then I can take my car out for a ride ?
I want to drive with a Map sensor instead of the afm is that possible and what do I need for that ?
Best regards
Simon from Sweden ( sorry if you don´t understand)
Your going to need the pressure sensor as well as the pressure sensor harness. Also get a usb cable to connect to pc.
It is just bolt on and go, although you need to connect it to a laptop or pc to configure it before you start it the first time. This is to tell the emanage what type of car its connected to and what it has that isnt standard. Once its configured it will still be outputting the exact same ignition and fuel signals as the standard ecu signal thats coming in. The maps need to be adjusted on a laptop via a usb cable to make any changes to the ignition or fuel ect.
When you have done this, you will need to create a map BEFORE connecting up the map sensor and removing the air flow meter. This is explained on this thread a few pages back.
This might be a crazy idea, and I'd say someone has tried it before:
To upgrade injectors on my r33, leave standard FPR, Injectors and rail.
Buy (1) 900 to 1000 cc top feed high impedance injector. $80
Using the emanages extra injector driver chanel, weld a bung into the intake pipe before the throttle plate for the injector.
Make up a hose from the rail to the injector and bring it into operation at around 4000 rpm.
6 * 380cc = 2280
6 * 555cc = 3330
6 * 380cc + 1000cc = 3280
Any thoughts?? :rofl:
Cheers for the advice really appreciate it, think I might go for the ultimate, the modifying process is a never ending one as i'm sure you know. So better to be prepared.
I had an Ultimate in my R33 GTS-t and it could never be tuned right.
It was boost spiking at certain levels(between 2500 & 4000) despite proper tuning!
Ripped it out and popped in a Power FC!
Best thing i ever did.
tuned or installed incorrectley 1000000%
r33 is a piece of piss and works fine... done around 30 now.
Sorry to dig up this post, but I have a question about the EMU that has not been addressed at all in this thread.
Will the rev limiter cut function work with the RB20/25/26 ECU's? I have tried in vain to raise the rev limit of my S1.5 RB25DET using this feature. No matter what I set the TP%, cut time, hold & limit values, and injector duty cycle times to, the engine will not rev past 7000 rpm. I am using the P&P N-4 harness with my EMU, and have repinned it accordingly.
If anyone out there has gotten this to work, please share what you've done. Thanks!
BTW, I am in the U.S. and have the 25 squeezed into my S14a (will link pix if requested) :)
URAS, I also PM'd you about this and a few other things but have not heard back. If you have some time I'd really appreciate a response.
BTW, I am in the U.S. and have the 25 squeezed into my S14a (will link pix if requested) :banana:
sorry i get bombarded with pm's so i miss a few :blush: can you email me a datalog of the car hitting rev limit say in 3rd? and also your map, i will then try figure it out and send it back ASAP. i will also explain how to do it based on your info :)
email it to [email protected]
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
