  • Replies 765
Had a fair crack at fixing the ignition and fuel maps this morning.
Adjusted the scale on the A/F target, Ignition, and INJ1 to:
Start at 4000 rpm and finish at 7200 for rpm's
Start at 3.0V and finish at 5.0V for input voltage.
Still got a fuzzy bit in the ignition timing around 6000 rpm's where the timing goes from + to - with only one row of 0's seperating them.
Might have to space it out a bit further apart with the scale changer.
Heres a pic of my new datalog:
Still some work to do, but the AFR's are looking really nice now. Power delivery is very much improved.
nearly_fixed.doc
what is the serial number on the back?
hey got mad082 to help he changes 1 and 6 around and it works okay still has a small miss. what should pulse rate be??? there 550 cc inj
Could you please tell me exactly what was swapped around to fix the miss you said you had on your injectors UCD15R33?
You said someone changed 1 and 6 around? You mean removed and swapped injectors around or whats the go?
Just curious what fixed it for you because I had a severe miss with one of the injectors I was using.
Mad082- he swaped my injector 1 and 6 and resealed them using grease cause number 6 wasnot sealing. But now I need lag time cause it has a miss when u add loan and a/f ratio is very lean.
Hello
I want to install the e-manage ultimate in my r33 gts25t spec 2 -97
What do I need more than this ?
https://www.rhdjapan.com/jdm/TRUST-E-Manage...c-Harness-24517
for ecr33
and the Ecu https://www.rhdjapan.com/jdm/TRUST-E-Manage...Main-Unit-18517
Does I need any moore parts ?
Is it just bolt on and then I can take my car out for a ride ?
I want to drive with a Map sensor instead of the afm is that possible and what do I need for that ?
Best regards
Simon from Sweden ( sorry if you don´t understand)
Your going to need the pressure sensor as well as the pressure sensor harness. Also get a usb cable to connect to pc.
It is just bolt on and go, although you need to connect it to a laptop or pc to configure it before you start it the first time. This is to tell the emanage what type of car its connected to and what it has that isnt standard. Once its configured it will still be outputting the exact same ignition and fuel signals as the standard ecu signal thats coming in. The maps need to be adjusted on a laptop via a usb cable to make any changes to the ignition or fuel ect.
When you have done this, you will need to create a map BEFORE connecting up the map sensor and removing the air flow meter. This is explained on this thread a few pages back.
hey im working on getting a new interface for the ultimate up and running, can someone post up a ultimate datalog? or email me one NOW? i left all my shite at home :( and need it it kinda urgent so they can decipher it.
[email protected]
This might be a crazy idea, and I'd say someone has tried it before:
To upgrade injectors on my r33, leave standard FPR, Injectors and rail.
Buy (1) 900 to 1000 cc top feed high impedance injector. $80
Using the emanages extra injector driver chanel, weld a bung into the intake pipe before the throttle plate for the injector.
Make up a hose from the rail to the injector and bring it into operation at around 4000 rpm.
6 * 380cc = 2280
6 * 555cc = 3330
6 * 380cc + 1000cc = 3280
Any thoughts?? :rofl:
Cheers for the advice really appreciate it, think I might go for the ultimate, the modifying process is a never ending one as i'm sure you know. So better to be prepared.
I had an Ultimate in my R33 GTS-t and it could never be tuned right.
It was boost spiking at certain levels(between 2500 & 4000) despite proper tuning!
Ripped it out and popped in a Power FC!
Best thing i ever did.
tuned or installed incorrectley 1000000%
r33 is a piece of piss and works fine... done around 30 now.
Sorry to dig up this post, but I have a question about the EMU that has not been addressed at all in this thread.
Will the rev limiter cut function work with the RB20/25/26 ECU's? I have tried in vain to raise the rev limit of my S1.5 RB25DET using this feature. No matter what I set the TP%, cut time, hold & limit values, and injector duty cycle times to, the engine will not rev past 7000 rpm. I am using the P&P N-4 harness with my EMU, and have repinned it accordingly.
If anyone out there has gotten this to work, please share what you've done. Thanks!
BTW, I am in the U.S. and have the 25 squeezed into my S14a (will link pix if requested) :)
URAS, I also PM'd you about this and a few other things but have not heard back. If you have some time I'd really appreciate a response.
BTW, I am in the U.S. and have the 25 squeezed into my S14a (will link pix if requested) :banana:
sorry i get bombarded with pm's so i miss a few :blush: can you email me a datalog of the car hitting rev limit say in 3rd? and also your map, i will then try figure it out and send it back ASAP. i will also explain how to do it based on your info :)
email it to [email protected]
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
