Hi security thanks for the response, my universal harness has 3 plugs at the ultimate end. ie theres no more room for any other plug into the unit. Surely this means that i have all the necissary wires to control the ignition and the injectors. if not where does it plug into?
Only the blue emanage has separate INJ and IGN harnesses, the ultimate only has one complete universal harness with three plugs..
  • Replies 765
Hi mate, a quick one
I have an R33GTST, how muchy would it cost and what is actually necessary to buy for an Gredy Emanage Ultimate to be pluged into the car.
What other sensors and harneses are necessary?
Also do they come with base maps to drive arround on?
since you still use your stock ecu, it doesn't need a base map. when you first hook it up it has no base map you just continue to run off the stock ecu settings. then when you start tuning all you are doing is altering the stock signals.
humm so propably best used with a stock computer, at the moment i have a central 20 ecu.
nah fine to use what you got, it already has the limiters moved etc makes it quicker to tune
hi mate there are no stupid questions but i need to know something.
i am buying an emanage ultimate. it comes with a cable and stuff, basic pack for $800.
wondering, they also have a seperate loom for$250. do i need to buy that as well. does that just allow it to plug into the stock ecu?
Couple of questions.
I have a R34 GTT.
Which parts will i require to install EMU?
I assume that the PnP is still not available yet?
Since the PFC and EMU give very similar gains, i don't see the need to fork out $1500 EXCEPT for the fact they have the hand controller which lets you monitor knock.
Does the EMU have a function where u can monitor knock?
Might hook it up to a laptop just to see if i can make sense of something, but i'm not an ECU person.
Also, i saw you mention Launch Control.
Is this a built in function of EMU or a seperate module?
And whats the difference in running a PFC with a Z32 AFM and running the EMU with no AFM?
Cheers
Trent can I run an Innovate LC-1 with the greddy Ultimate
or is it only the LM-1 ??
also on the Knock sensor wires I was told to wire in the Knock sensor number 2 as its the one at the back of the block and listens to the back cylinders
does that sound about right to you ??
lc1 is fine. You will just need to program the outputs to suit the inovate voltage/AF ratio the EMU expects which is 7.35 A/F @ 0v - 22.39 A/F @ 5v from memory.
Hi i have an r33 rb25det s2. i got my plug and play loom today. is the n-4 but i need the n-6. whats the difference i cant find any. what do i need to modify to make it work for my rb25det s2? any one. thanks
One more cuestion. i want to remove my maf. In this lines Trent talks about select pressure sensor ok no problem with that but, the part log its voltages? is the same as afm 2v to 5v? if is 2-5v for some reason the program dont allow me to go beyond 4.5v in the grreddy pressure sensor seting. any one thanks
How to remove AFM;
This is a simple operation that requires the optional greddy pressure sensor to be plugged into either of the inputs on the front of the emanage (yellow plugs).
open data sampler map (far right toolbar icon)
turn data sampler ON (click on/off icon)
select greddy pressure sensor and log its voltages (you will need to select greddy pressure sensor in the IGN and INJ too )
drive vehicle and populate as much of the sample screen as possible (safest to do on dyno or track) but road is fine if you have enough demerit points
cut and past this populated data into the AIRFLOW OUTPUT map.
done
Edited by nomenai
sup guys i have a emu sitting on my desk. my question= im putting in bigger turbo, injectors, z32/q45 afm, and it has a exhaust fmic etc, splitfires, iridium plugs.
do i just wack in the emu. will i need to buy any special harnesses to control the injectors or ignition, or will it all be sweet, is it all built in?
    • I keep seeing supercharger kits for these listed on marketplace 😂
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
