Hi!
I wanted to ask some questions about the setup I want to buy.
1.Innovative LM1 or LC1
2.EMU
3.GTR harness ? Or plug and play ?
4.A/F harness or pressure sensor for Innovative ?
I got hcr32 rb20det wired in my x-carby a31 car. I want to be able to do road tuning on my own. So I want a wideband to work with EMU and emu to act as a datalogger as well. So when I do some road tuning I get all the needed parameters datalogged by EMU and then make adjustments to the maps. Can it be done ?
Thanks!
Edited by robots
  • Replies 765
yes that what u need. The innovative 02 is what im running in my seris 1.5 skyline. The gtr harness will have to be modified to make it a gtst harness the wires that need to be cut are on the first pages of this thread. can get both the presure sensor and the a/f harness so u get correct boost pressure and the a/f with be on the emange data logger screen. And it can be done road tunning just make sure you have enough points on ur licences to do it lol :-)
ive heard conflicting opinions on the innovative wideband's. something about them needing recalibration every day, and that the plx wideband's were the way to go. they even come with a little gauge.
the e-01 doesnt work with the ultimate. according to URAS, greddy are releasing something similar for the e-01 sometime into the future for the ultimate.
Edited by SECURITY
had no issues with my LM-1 from innovate. had it for 3-4 years..... sensors last pretty well, about the same as any other and are available anywhere ($90-120) as the are just a bosch.... PLX and Innovate use the same sensor :D part number 0258007057
Heya Torentski,
I don't have an ingriss manual on me only the jap one therefore I have a silly question :D
Can I run low impediance GTR injectors on my R32 RB20DET engine with the ultimate "without" the use of a resistor pack?
I was thinking (dangerous I know) of selling my denso 550cc high impediance ones and getting some Blitz GTR injectors and it would be handy not to have to wire in the resistor pack.
cheers
-Jez
Heya Torentski,
cheers
-Jez
Nah you need to stick with the factory impedance, or wire in the resistor pack :domokun: easy if you have a plug and play loom ;)
With some feedback from http://www.emanageforums.com/ I found the source of my ignition timing problem (ie EMU reading constant 111.0deg in data logging). The problem is the cam and crank signal wires in the Install Manual and the plug and play loom are the wrong way around. Apparently there is an updated install manual which makes note of this but i'm yet to find it.
Unfortunately for me it didn't fix my car idling/running rough but it's progress :)
With this change I repeated troubleshooting including changing RPM Signal and reinstalling EMU software/firmware but no change. I have the injector adapator for 6 cylinders on it's way so will see if this helps.
Wegs
Unfortunately for me it didn't fix my car idling/running rough but it's progress :worship:
Wegs
sorry i thought i posted this up somewhere?? bugger as the JDM plug and play looms for series two S14 do the same thing unless swapped around to the differrent (aus spec) wiring.... much like s15 PFC pin swap.
as far as running rough have you taken the lag time out of the inj settings yet?
Trent
How much lag should we be taking out
just go .1ms at a time till it stops idling rich ???
delete lag times in the before and after, so it shows nothing.
I have noticed that the input and output voltages for the afm are different. The emanage outputs slightly more voltage than is coming in....
At idle there is about 0.03 to 0.08 more volts. I think if the voltage is different, and im running standard injectors and afm, that its going to cause problems with the standard ecu trying to compensate fuel and timing?
Should the afm map be adjusted in its entirety to reduce the voltage back until the input and output match at idle?
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
