  • Replies 765
Had a fair crack at fixing the ignition and fuel maps this morning.
Adjusted the scale on the A/F target, Ignition, and INJ1 to:
Start at 4000 rpm and finish at 7200 for rpm's
Start at 3.0V and finish at 5.0V for input voltage.
Still got a fuzzy bit in the ignition timing around 6000 rpm's where the timing goes from + to - with only one row of 0's seperating them.
Might have to space it out a bit further apart with the scale changer.
Heres a pic of my new datalog:
Still some work to do, but the AFR's are looking really nice now. Power delivery is very much improved.
nearly_fixed.doc
what is the serial number on the back?
hey got mad082 to help he changes 1 and 6 around and it works okay still has a small miss. what should pulse rate be??? there 550 cc inj
Could you please tell me exactly what was swapped around to fix the miss you said you had on your injectors UCD15R33?
You said someone changed 1 and 6 around? You mean removed and swapped injectors around or whats the go?
Just curious what fixed it for you because I had a severe miss with one of the injectors I was using.
Mad082- he swaped my injector 1 and 6 and resealed them using grease cause number 6 wasnot sealing. But now I need lag time cause it has a miss when u add loan and a/f ratio is very lean.
Hello
I want to install the e-manage ultimate in my r33 gts25t spec 2 -97
What do I need more than this ?
https://www.rhdjapan.com/jdm/TRUST-E-Manage...c-Harness-24517
for ecr33
and the Ecu https://www.rhdjapan.com/jdm/TRUST-E-Manage...Main-Unit-18517
Does I need any moore parts ?
Is it just bolt on and then I can take my car out for a ride ?
I want to drive with a Map sensor instead of the afm is that possible and what do I need for that ?
Best regards
Simon from Sweden ( sorry if you don´t understand)
Your going to need the pressure sensor as well as the pressure sensor harness. Also get a usb cable to connect to pc.
It is just bolt on and go, although you need to connect it to a laptop or pc to configure it before you start it the first time. This is to tell the emanage what type of car its connected to and what it has that isnt standard. Once its configured it will still be outputting the exact same ignition and fuel signals as the standard ecu signal thats coming in. The maps need to be adjusted on a laptop via a usb cable to make any changes to the ignition or fuel ect.
When you have done this, you will need to create a map BEFORE connecting up the map sensor and removing the air flow meter. This is explained on this thread a few pages back.
hey im working on getting a new interface for the ultimate up and running, can someone post up a ultimate datalog? or email me one NOW? i left all my shite at home :( and need it it kinda urgent so they can decipher it.
[email protected]
This might be a crazy idea, and I'd say someone has tried it before:
To upgrade injectors on my r33, leave standard FPR, Injectors and rail.
Buy (1) 900 to 1000 cc top feed high impedance injector. $80
Using the emanages extra injector driver chanel, weld a bung into the intake pipe before the throttle plate for the injector.
Make up a hose from the rail to the injector and bring it into operation at around 4000 rpm.
6 * 380cc = 2280
6 * 555cc = 3330
6 * 380cc + 1000cc = 3280
Any thoughts?? :rofl:
Cheers for the advice really appreciate it, think I might go for the ultimate, the modifying process is a never ending one as i'm sure you know. So better to be prepared.
I had an Ultimate in my R33 GTS-t and it could never be tuned right.
It was boost spiking at certain levels(between 2500 & 4000) despite proper tuning!
Ripped it out and popped in a Power FC!
Best thing i ever did.
tuned or installed incorrectley 1000000%
r33 is a piece of piss and works fine... done around 30 now.
Sorry to dig up this post, but I have a question about the EMU that has not been addressed at all in this thread.
Will the rev limiter cut function work with the RB20/25/26 ECU's? I have tried in vain to raise the rev limit of my S1.5 RB25DET using this feature. No matter what I set the TP%, cut time, hold & limit values, and injector duty cycle times to, the engine will not rev past 7000 rpm. I am using the P&P N-4 harness with my EMU, and have repinned it accordingly.
If anyone out there has gotten this to work, please share what you've done. Thanks!
BTW, I am in the U.S. and have the 25 squeezed into my S14a (will link pix if requested) :)
URAS, I also PM'd you about this and a few other things but have not heard back. If you have some time I'd really appreciate a response.
BTW, I am in the U.S. and have the 25 squeezed into my S14a (will link pix if requested) :banana:
sorry i get bombarded with pm's so i miss a few :blush: can you email me a datalog of the car hitting rev limit say in 3rd? and also your map, i will then try figure it out and send it back ASAP. i will also explain how to do it based on your info :)
email it to [email protected]
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
