lol yea flashing greenish color. but in the manual it says that relates to error codes?!?!?!
my knock sensor doesnt read, but this is only on starting, will it only register once engine running?
It will only show actual real time knocking, so if it aint knocking it wont show.
and my water temp C NS_WT-1 reads about 70-80c, and when i switched the jumper it reads -16 or something, which is correct?
70-80 whilst running or stationary and cold? if it says 70-80 when cold then it is wired wrong.
  • Replies 765
I want to clear some things once and for all.
Some guys running EMU on sr20det experience some rich idle a/frs, fuel cuts.
Some guy on emanage forums, said that moving the jumper 8 from 1-2(default greddy) to 2-3 cured his problem.
Its the jumper for the ignition output signal. Greddy Default is 5v(jumper set to 1-2) and jumper set to 2-3 makes it 12v.
So can someone pls confirm: what configuration should rb20/rb25/rb25neo/rb26 guys run ?
Reading the EMU faq I thought rb2neo guys benefit from going to 12v ignition output signal.
Thanks in advance!
Edited by robots
^^^^^ sorry in my first post in this forum i mentioned that all cars should be run (jp 8 2-3 ) 12v.... sorry i did not mention it :ninja: i assumed you had already done that.
if you want more info see first post.
So I should set the jumper 8 to 2-3 and it will help you reckon ? ))) Haha. I feel kinda happy again ))
Thanks!
Yeah definately, jumper 8 set at 2-3 bypasses an ignition circuit inside the emanage.
Even though it is 5v / 12v jumper it cannot jump the 5v signal to 12v.... whatever voltage goes in can only ever come out the same voltage. The issue arises with some cars that have "dirty" signals, these signals are further modified by the 5v circuit and can play up causing misfires and so forth.
I set ALL emanage ultimates up at 2-3 (JP8) and work from there, i have NEVER had an ignitor failure in over 40-60 installs. (this info is based on a conversation i had with ichida-san who designed the EMU)
hey guys. just wanted to know what to set my knock sensor to.,
uras, or whover.
how do i set it up.
atm the jumper for it is set to 1-2. and in parameters im using the air intake temp/knock sensor 2 with it set to resonate and 7.02.
is this cool??
^^^^^^^ no one knows?
also i REALLY NEED a good tuner of a emu in the sunshine coast/brissie area.
can anyone recommend anyone, and how long and much will it be?
Hi Guys,
My EMU was installed & tuned by a workshop, but the guy who did the work is away at the moment.
1st time I connected my laptop to the EMU, I spotted a huge error log. Any ideas?
my car is an R34 GTT (manual).
[2008/01/26-15:19:09]------------------------
65504:0443-0006[incorrect 3CH ignition input signal]
65505:0444-0003[incorrect 4CH ignition input signal]
65506:0445-0001[incorrect 5CH ignition input signal]
65507:0446-0002[incorrect 6CH ignition input signal]
65508:0441-0004[incorrect 1CH ignition input signal]
65509:0442-0005[incorrect 2CH ignition input signal]
65510:0443-0006[incorrect 3CH ignition input signal]
65511:0444-0003[incorrect 4CH ignition input signal]
65512:0445-0001[incorrect 5CH ignition input signal]
65513:0446-0002[incorrect 6CH ignition input signal]
65514:0441-0004[incorrect 1CH ignition input signal]
65515:0442-0005[incorrect 2CH ignition input signal]
65516:0443-0006[incorrect 3CH ignition input signal]
65517:0444-0003[incorrect 4CH ignition input signal]
65518:0445-0001[incorrect 5CH ignition input signal]
65519:0446-0002[incorrect 6CH ignition input signal]
I had a look at some of the wiring today (before I ran out of daylight)
The Ign Input Ch1, 2 and 3 looked to be wired correctly (according to the EMU wiring instructions)
I did find about 6 wires that weren't connected, but they didn't seem to be related to the ignition.
I look some photos so I could go back and double check... still scratching my head!
    • Hey y'all, Looking local to USA, for just side skirts and rear bumper or half bumper. Pics for reference below: Top is east bear style rear bumper, bottom is uras style rear half bumper. Side skirts are interchangeable.  Thanks y'all!
    • Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this. Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't". Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed. Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod. Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
    • Yes I'm going through a similar thing with my R33 with rust in seams due to dried out seam sealer cracking. After much research I settled on Penetrol. Read what it does and its done a bloody fantastic job for me. Pressure pack comes with a thin tube to get into hard to reach places.
