  • Replies 765
Quick update Trent
Got sent a map from one of the guys on the SOC forum and tried it last night and the car ran perfectly. Came to the car this morning and running rough as hell again, with a definate smell of petrol until the engine died. Reconnected the stock ecu and ran fine. Drove the car 25 miles to work no problem. At work reconnected the emu and now the car won't even start. Is this starting to indicate a potential problem with the emu hardware? Harness should be OK, as it is a genuine Greddy N4 harness. Totally lost what to do next other than chuck the lot in the bloody bin and give up! :O
I've come across one annoying problem with the emanage, while stuffing around with the laptop when connected to the emanage with the car running somehow the map becomes corrupted and car runs megga rich on idle and can't rev past about 2 grand. However the problem is easily fixed, start a new map and then copy all the infomation across to the new map and car runs fine again....wierd.... its done this to me twice now.
Anyone know what a safe rev limit is on RB25 I want to push it up just a bit to say 7200, 6800 doesn't seem enough.
Edited by SevenAngryPenguins
I've had that happen too, but not since the latest software upgrade. When it's happened I've looked at the datalog and the emu has stopped outputting an afm signal. Start a new map and it's all fine again.
The hydraulic lifters on mine started complaining at 7500 so I wouldn't go above 7200. Personally, I left it at 7000 as I really don't need any more revs. Especially with a 3.7:1 ratio diff :O
Yeah there was an old glitch in the software that did that on occasion but the new updates have cleared that up.
Quick update Trent
is the temp reading accurate i the EMU datalog? if not you need to swap jumpers. D board does not have the inbuilt temp vs inj adapter built in.
which software update is that? I'm running 2.16 downloaded from mohdparts.com
yeah, is the emu updated? as i have not had that issue for months now.
um, emu has the 2.16 firmware as well it seemed to of done it when the laptop shut down and had to be restarted, well I think
yeah check it updated, then load say rb20 into your EMU then start a complete new rb25 setup file and load that into the EMU and see if it fixes your issues.
ok will do I'm pretty sure it updated the first time I connected it after the update though. Your boost cut settings worked as well thanks for that, I just had to change one of the settings a bit lower and it was all good. I Think my rubber intake was sucking closed as well, I reinforced it after the boost cut settings didn't work at first.
Hi guys.... I plugged in and turned on my EMU yesterday. So many questions....
Firstly, I have a D board, is this a major issue???? Trent, if it is, can we do a deal re your spare E board?
Secondly, when I had it on the dyno (I got some free time from a place I used to work at), I couldnt make any changes stick.... I.e. whenever I changed the airflow adjustment map, the stock ECU brings the values back to lambda.... How do i get rid of this, as in turn on closed loop?
I'll think of some more no doubt
if you want to tune in closed loop areas disconect the o2 sensor. Also dont use the airflow adjustment map use the injector map.
happy tuning :thumbsup:
I have a question regarding the airflow adjustment map. I have been tuning the car using the injector map and have got the afr's pretty good but not quite perfect as the afr can change a little bit from within the same rpm tuning square. I think I read in this thread somewhere that you can use the airflow adjustment to fine tune the afr by changing the maps scale for finer adjustment. Is this still possible when my airflow meter is maxed out? I only really want to clean up my high rpm afr's
use injector map 2 and set your scale from where you want to clean up, for example you have a weird spot at 6250 you camn actually run the map scale from 6000 to 7000 (6000-6500 etc) and have the scale real specific around your problem (see attached pic)
you can do the same with timing. All secondary maps work on top of map 1 so any adjustments on map2 will be added to map1 ; so if you have plus 15% fuel in map1 at 6250 and 5% at 6250 in map2 you will have a total of 20% extra fuel at 6250.
hope it helps
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
    • The suspense is killing me lol.  Are you going to buy a flex sensor, then add the 98 tune to your current tune?  It sounds like your just going to delete the current tune and re-tune the car on 98 =/ If you've only known your car on e85, I don't think it will be long before you install the flex sensor and go back to running e85 when its available lol.
    • Currently on an e85 only tune, but I barely get 200km from a full tank. Makes going for longer drives difficult, especially when u leave Melbourne metro as there aren’t many united servos, hence why I’m thinking of going more of a 98 setup.    And yes the smell lol. Any drive afterwards I need to have a shower and wash all the clothes I was wearing, it’s like someone made a Calvin clown e85 perfume and sprayed it all over me haha
