STATUS Posted September 23, 2008 Author Share Posted September 23, 2008 You got a dyno readout on that R34 Trent also what supporting mods did it have im looking at trying for around 270 myself and was it a standard auto ? will get it up 2moro, yes std auto. Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4151433 Share on other sites More sharing options...
SECURITY Posted October 13, 2008 Share Posted October 13, 2008 Trent, I still cant convert my car to run with the MAP sensor. it idles okay, but if i put my foot down it hesitates then revs. its also hard to start. i spent 2hrs getting the maps right, even used the inj map to adjust fuel but its still not good enough to drive around with. any clues? Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4192873 Share on other sites More sharing options...
STATUS Posted October 27, 2008 Author Share Posted October 27, 2008 You got a dyno readout on that R34 Trent also what supporting mods did it have im looking at trying for around 270 myself and was it a standard auto ? Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4220306 Share on other sites More sharing options...
pear Posted October 28, 2008 Share Posted October 28, 2008 Hey guys, i've picked up an innovate LC-1 - have many ppl connected these to their emu? any detailed setup/instructions for R34 GTT? i was talking to a guy in perth that had everything setup, but the emanage forum is down and i've lost contact Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4223414 Share on other sites More sharing options...
scags Posted November 17, 2008 Share Posted November 17, 2008 Hey guys, i've picked up an innovate LC-1 - have many ppl connected these to their emu? any detailed setup/instructions for R34 GTT? i was talking to a guy in perth that had everything setup, but the emanage forum is down and i've lost contact Hey Pear, Your lucky day - I'm the guy from Perth I've attached my notes - An Excel Spreadsheet with 3 tabs. each tab shows a device (LC-1, Old Oxygen Sensor, EMU) and what the cables were connected to and should be changed to. I made my own EMU front panel connector using a internal computer audio plug - worked better than I expected. The hardest bit was running the wiring between the engine bay and the cabin. LC-1 is working great - I've used the EMU auto tune function to help home in on my desired AFR. On to Knock and ignition timing now, but I've hit some sort of turbo pressure issue I've got to sort. I'm also spewing the emanageforums site is down - what's going on there! Hope this helps, Scags LC1_Skyline_ER34.zip Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4267311 Share on other sites More sharing options...
Haines Posted November 18, 2008 Share Posted November 18, 2008 (edited) you are pretty sort after guy at the moment Scags LOL Im also chasing that info And on the emanage forums I believe it had something to do with the stockmarket crash Pear knows more Edited November 18, 2008 by Haines Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4267643 Share on other sites More sharing options...
antomx Posted November 21, 2008 Share Posted November 21, 2008 Id like to say this is probably the best info on the EMU i've seen on the net and I've been pouring a ton of hours in searching, much thanks to URAS and all others who know what they are doing with the EMU,Anyway.. Had a few questions, Ive got a series 2 Rb25det ive stuffed into an S14, all S14 wiring gutted and nothing but R33 wiring in it. (yeah I live in the states) Ive got an EMU that I'm about to wire in and plan on doing the AFM elimination. So after I log the greddy pressure sensor vs. RPM and get as much data as possible and put that into the airflow output map and interpolate the rows and such, get the numbers looking and working good... Im guessing im going to max those numbers somewhere in that layout and hit boost cut. Ok so I clamp the voltage rite before that happens...now the ECU never sees the voltage but i still need fuel and timing correction beyond that point, soooo..... Do I go to the injector and ignition maps and put in the values i need there? or do I use the aux. map or something else? Also what if some of the values inputted into the airflow output map overlap something you've put in these other maps? which one wins? Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4276525 Share on other sites More sharing options...
bnr32_700ps Posted November 24, 2008 Share Posted November 24, 2008 (edited) Hi guys. I've just installed EMU to my car and have 2 problems. The ignition timing in the datalog show that it currently running on 110degree btdc when idling and it doesn't change when the rpm change. And also the EMU didn't sensing any knock when the engine under full load and show 0 knock on the datalog. What did I do wrong? Is it the wiring or setup in the jumper or software? Anyone can help? Thanks. Edited November 24, 2008 by bnr32_700ps Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4280644 Share on other sites More sharing options...
Haines Posted November 25, 2008 Share Posted November 25, 2008 for starter your knock should be set to resonant 7.02 and as for the 111 deg problem its a wiring prob i believe or jumper setting Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4283056 Share on other sites More sharing options...
robots Posted November 25, 2008 Share Posted November 25, 2008 swap the cam and crank angle wires. will do the trick. You wired it wrong. Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4283825 Share on other sites More sharing options...
STATUS Posted November 26, 2008 Author Share Posted November 26, 2008 swap the cam and crank angle wires. will do the trick.You wired it wrong. yup Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4284173 Share on other sites More sharing options...
scags Posted November 27, 2008 Share Posted November 27, 2008 for starter your knock should be set to resonant 7.02and as for the 111 deg problem its a wiring prob i believe or jumper setting Hey Haines, How certain are you we should have our kncock set to "resonant" and 7.02? I ask because I want to be sure I can trust the signal I am getting before I advance my timing much more. Isn't the frequency dependent on the bore and stroke of the engine? Does that mean it wouldn't be the same for different models of skylines? I had a good thread going on this before emanageforums went down So much information lost in a matter of senconds. I hope someone is able to revive the information that had been gathered at that site... You said I'm sort after? Who else is looking for me? JJ Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4287738 Share on other sites More sharing options...
Haines Posted November 27, 2008 Share Posted November 27, 2008 (edited) I think it may actually be non-resonant and i have just read it on forums mines set to that and seems to be working Edited November 27, 2008 by Haines Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4287804 Share on other sites More sharing options...
SECURITY Posted December 1, 2008 Share Posted December 1, 2008 Id like to say this is probably the best info on the EMU i've seen on the net and I've been pouring a ton of hours in searching, much thanks to URAS and all others who know what they are doing with the EMU,Anyway..Had a few questions, Ive got a series 2 Rb25det ive stuffed into an S14, all S14 wiring gutted and nothing but R33 wiring in it. (yeah I live in the states) Ive got an EMU that I'm about to wire in and plan on doing the AFM elimination. So after I log the greddy pressure sensor vs. RPM and get as much data as possible and put that into the airflow output map and interpolate the rows and such, get the numbers looking and working good... Im guessing im going to max those numbers somewhere in that layout and hit boost cut. Ok so I clamp the voltage rite before that happens...now the ECU never sees the voltage but i still need fuel and timing correction beyond that point, soooo..... Do I go to the injector and ignition maps and put in the values i need there? or do I use the aux. map or something else? Also what if some of the values inputted into the airflow output map overlap something you've put in these other maps? which one wins? Ive found that it works best when you do a voltage clamp vs. throttle position. nothing else has worked properly for me. What you can do is do a map trace and when you feel 'boost cut' change your values in the Airflow Output Map (where you're putting your voltage clamp data) to a lower value to bypass it. the map trace will tell you which values you're reaching 'boost cut' on so all you need to do is change the values in the highlighted boxes. the WORST issue i had was cold start with the MAP sensor running. it would run like an absolute pig. i ended up buying an EEE PC just to have in the car with only the emanage software installed so i can adjust the cold start voltage when i turn it on in the mornings! The problem is on cold start the AFM voltage is around 1.70 on idle, then when it gets to operating temp it sits at ~ 1.06. the 1.06v on cold start makes it run like crap and VERY lean. I even tried playing with the temp adjustment map to add fuel but it only worked to a maximum of +20%, i needed at least 40% adjustment for the afr's to be anywhere near the right value to idle properly. Trent, do you have a fix for this? Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4293897 Share on other sites More sharing options...
antomx Posted December 1, 2008 Share Posted December 1, 2008 (edited) Ive found that it works best when you do a voltage clamp vs. throttle position. nothing else has worked properly for me.What you can do is do a map trace and when you feel 'boost cut' change your values in the Airflow Output Map (where you're putting your voltage clamp data) to a lower value to bypass it. the map trace will tell you which values you're reaching 'boost cut' on so all you need to do is change the values in the highlighted boxes. the WORST issue i had was cold start with the MAP sensor running. it would run like an absolute pig. i ended up buying an EEE PC just to have in the car with only the emanage software installed so i can adjust the cold start voltage when i turn it on in the mornings! The problem is on cold start the AFM voltage is around 1.70 on idle, then when it gets to operating temp it sits at ~ 1.06. the 1.06v on cold start makes it run like crap and VERY lean. I even tried playing with the temp adjustment map to add fuel but it only worked to a maximum of +20%, i needed at least 40% adjustment for the afr's to be anywhere near the right value to idle properly. Trent, do you have a fix for this? So you're still keeping the airflow output map on greddy sensor when doing all this right? and doing all the clamping there and not even using the boost limiter map? Edited December 1, 2008 by antomx Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4294692 Share on other sites More sharing options...
STATUS Posted December 1, 2008 Author Share Posted December 1, 2008 (edited) The problem is on cold start the AFM voltage is around 1.70 on idle, then when it gets to operating temp it sits at ~ 1.06. the 1.06v on cold start makes it run like crap and VERY lean. I even tried playing with the temp adjustment map to add fuel but it only worked to a maximum of +20%, i needed at least 40% adjustment for the afr's to be anywhere near the right value to idle properly.Trent, do you have a fix for this? Hmm not had this issue, i would try juggling the afm voltage in the output map to mid way between the two, bit on the rich side at idle say 12.5-13 instead of 14 ish and see if you can get enough cold start in there. without playing with it here it is a bit hard sorry. Edited December 1, 2008 by URAS Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4294703 Share on other sites More sharing options...
Haines Posted December 1, 2008 Share Posted December 1, 2008 ive had to set my idle Afrs at 12.5- 13.5 if it gets any leaner it wants to miss Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4294886 Share on other sites More sharing options...
STATUS Posted December 1, 2008 Author Share Posted December 1, 2008 ive had to set my idle Afrs at 12.5- 13.5 if it gets any leaner it wants to miss where is your AFR sensor? ps did you get map via email? Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4294891 Share on other sites More sharing options...
Haines Posted December 1, 2008 Share Posted December 1, 2008 sure did mate also sent you a few more emails back im running the lc1 and i have it in the dump pipe at the bend about 12" away from exhaust housing Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4294981 Share on other sites More sharing options...
STATUS Posted December 2, 2008 Author Share Posted December 2, 2008 (edited) Just did a stagea and i get alot of enquiries on them so i thought id share anothr i did the other day for a fellow SAU'ER Edited December 2, 2008 by URAS Link to comment https://www.sau.com.au/forums/topic/161460-e-manage-ultimate-emu-56k-beware-screen-shots/page/32/#findComment-4295725 Share on other sites More sharing options...
