  • Replies 765
  • 3 weeks later...
Actually while im here,
What Map sensors work with the EMU?
Will GM ones work? they are much much cheaper than the Greddy ones from what I have seen,
Also where can I get the Greddy IAT sensor from...I want to run MAP with Intake temp correction, will any IAT sonsor work or only the Greddy one?
I have found this website
very lucky to still have access to it to be honest
so download everything you need while its still available
http://web.archive.org/web/*/http://www.mohdparts.com
Its the archives of the old Mohdparts website (the best emanage software and information website)
What have you guys done in regards to logging the AFM voltages to convert to MAP if the AFM is maxing out?
Say for example the standard AFM is maxing at 4500rpm at 1 Bar, do you drop the boost pressure down so you can get a full run to redline with out maxing it?
Im trying to figure out how I can do it.
  • 3 months later...
my boys and i are working on a project
Its a 1985 Mitsubishi gallant
replaced the engine wth an rb20det :-)
ill now tell you my setup as is the what i wana do soon just let me know what you think
and if you can give any advise or pointers that will be good
rite now we are running
*stock rb20 motor
*300zx 45v3 t3 turbo
*10 psi boost
*blitz bov
*blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*apexi n1 tail pipe
*gear box rebuilt
*upgraded ecu flashed\remaped by raymond of ems tuning( no cuts)
*exeddy street and strip clutch kit
*NGK iridium spark plugs
*All oil seals and belts changed
*walbro external fuel pump
*runnin on castrol syntec
future mods
*genuine Nissan total engine head and block rebuild kit
*turbonetics t3/t04B ball bearing turbo
*xo2 exhaust manifold
*turboxs manual boost controller
*side mount intake manifold
*Q45 throttle body
*sard fuel press reg
*rb26 injectors
*water/meth injection ket
*Greedy e-manage ultimate
*Greedy injector & ignition harnes
*pressure sensor so no AFM
*wide band o2
*cometic/tomie head gasket
*ARP main gurtle bolts
*ARP con rod bolts
*ARP head bolts
*HKS timing belt
*vented coil cover
*castrol edge
*oil cooler
*oil catch can
think thats about it
what do you think ?
  • 2 months later...
  • 1 month later...
Ok I have a random one here.
because im on a budget (or im a tight ass) im going to run wasted spark but instead of the factory ignitor i want to get an EMS 3ch one...or somthing similar.
how do i go about wiring it up? and with out looking at it im pretty confident on setting up the software side of it.
and ideas or links we can throw around?
thanks
Andrew
heres a wiring diagram for the EMS ignitor....
http://www.enginemanagementsystem.com/imag...%20no%2052A.pdf
  • 5 months later...
wow this thread is still here?
Anyway....I was wondering if anyone had an airflow output map from an RB25det setup...I dont care if its stock voltages or for a modified engine, I just need something to start from...My maf isnt working and instead of buying one to just log the voltages and then toss (have map sensor) I was hoping I could get out a little cheaper with some help from you guys. Im just now getting this car running so i never had a chance to log anything and this is the only thing holding me back....any and all that respond, it would be greatly appreciated.
Thanks
If your interested in my setup:
rb26 style intake
660cc injectors
.81 a/r turbo
stainless exhaust manifold
external wastegate
mahle pistons
eagle rods
255lph walhbro
FMIC
90mm throttlebody
head studds
Hey guys,
I am keen to get a new ecu for my r34 GT-T Skyline, I was thinking of getting a Haltech Platnium Sport 1000, but I have also been looking at the cheaper option of Nistune and maybe a piggyback ecu. My maximum power figure that I would be aiming for would be 300kw eventualy. I have done a fair bit of work with standalone ecu's before, so I am tending that way. I am just looking for something that may be simpler and cheaper but will still do what i need it too, the Greddy Emanage seems to be a good option.
Thanks Joel
