E-manage Ultimate (emu) 56k Beware (screen Shots)
STATUS
Hey guys,
I am keen to get a new ecu for my r34 GT-T Skyline, I was thinking of getting a Haltech Platnium Sport 1000, but I have also been looking at the cheaper option of Nistune and maybe a piggyback ecu. My maximum power figure that I would be aiming for would be 300kw eventualy. I have done a fair bit of work with standalone ecu's before, so I am tending that way. I am just looking for something that may be simpler and cheaper but will still do what i need it too, the Greddy Emanage seems to be a good option.
Thanks Joel
Nistune
  • Replies 765
Trent sent u a pm a lil while ago regarding emu/vman.
Do you have much expirence with vmanage..?
yeah, kinda pointless on alot of cars, the evos get good gains though.
Trent - by any chance has you tried E85 on a 1jz with the EMU? looking at doing it on my soarer cause we get 2 E85 servos here in the ACT this month and I have the Emanage lying around.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :thumbsup:
yeah its fine but you MUST wire up the coolant temp sensor as its needs lots on temp comp for cold start.
Thanks, was going to use the plug in loom to save hacking up the factory loom.
Im guessing it needs a bucket load more fuel when cold over factory.
yup.
Reckon factory 2jz 440's will be enough for the standard turbo's there is a set going cheap I can get my hands on.
Thinking I really should get some big ones straight up to make sure I have enought fuel for the future.
While Im thinking of it, would rb25 injectors fit the 1jz fuel rail, the plugs are different but thats an easy fix, asking cause I have set of high flowed 25det squirters sitting in the garage.
440's will be fine on petrol, they will see more power than your stock turbos can muster up. no chance on e85 though
and how cheap is cheap? they can be had regularly for $150...
aboot $100 bucks, I was more thinking just for the mean time, but the effort involved in swapping them over and then havng to go it all over again when I up the boost means I doubt Ill grab them.
just worked it out, the 2jz 440's are only 19% larger so no go for e85 even now, need 550s minimum :P
oh well.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :(
Wolf do a plug in for an auto soarer.
they do auto trans models.
are they preset will all the correct shift pressures and what not? if not the are no different to all other ecus.... all ecu's can run an auto if you know the solenoid switching and relevant input /outputs.
If it does thats pretty sweet, but i still wont touch them :D
at what cost though, It wouldnt be free, and CBF spending 2K on a ECU plus 1500 to tune, then have to f**k around if the auto flares badly or shifts to early etc etc and at the cost per hour for workshop rates isnt cheap.
Cause there is no way you can program and auto box in a hour of cruising round the back streets.
    • This may not cheer you up too much, but it really doesn't take much contact to crumple it back like that, and while any pre purchase inspection should have warned you it won't really change how the car feels as long as the panel mounting points are in the right spots so it looks right externally.  I would clean up and repaint the rust spots though
    • I decided my first mod would be a FMIC for it to gulp in some chilled air: When I removed the bumper to make a start on fitting it, that’s when it started to reveal its past to me. One very nasty looking buckled inner wing… …and a not so happy looking front panel and crossmember 😫
    • It didn’t look too bad, it was more what I found underneath when the modification itch started. It had clearly been used as a previous track weapon and suffered quite a smash to the front end.
    • That's completely fair. What are you playing these days?
    • This mornings bus ride went from Nelly- country grammar, to metallica- death magnetic
