hi all i am back on land of the skyline but now with r34 gtt auto i recently put on the following
e manage ultimate with ignition adaptor and set to 12v
with complete universal loom
specs are
nismo fuel pump
blitz 540cc injectors lag set to 1.02 and .60 for stock
and new roller bearing turbo unit with steel turbine
the problem i am having sometimes you can struggle to start
1 .when it start it idles fine etc but it has slight misfire once evry few seconds but revs very clean
2 . one you drive it after few minutes tcs and slip light will come on and stay on and canot switch it back on and sometimes it will stall
also how do i remove fuel cut
any help would be greatly apreciated
thanks
hi i found out why i am having problems see if anyone can help me in anyway . if the car slows down to 50mph i get check engine light come on for 1 second then go off this uts a airflowmeter tfault and causes tcs to stay on,
what i have noticed is that wen car gets to 50mph for a split secont the output afm signal go to 0v wich causes the problem
any ideas
  • Replies 765
any ideas
Either the wiring has a fault or more likely the afm has a loose connection inside. If you are handy with a soldering iron you could probably fix the dry jointed AFM pins, do a search for the "how to", or just replace it.
but why would it only do it at 50mph as it does not do it any other time
does anyone know, with the 'external switch', it is a 3.5mm jack, which has 3 pics on it. does the EMU need to see continuity between two of these to switch over, or do i give 12v to one of them? if so which particular pin?
has any one got a base tune for emanage blue rb25det. really need one asap.
no such thing, just delete the tune in it, once deleted car will run like std.
have you got the software and special cable?
delete all the info in the ecu, and only set the injector adjustment it is also in the software just put i the before and after sizes.
how do i wipe the entire tune? do i set all values to zero or is there a menu? yes i have the software and the cable, and yes i have a basic understanding of the software.
how do I wipe the entire tune? do I set all values to zero or is there a menu?
I gather I don’t need resistors on the injectors (JECS 550cc) high impedance? Any modifications to the coil packs S2 built in igniters, they are yellow jackets.
Jumper settings:
1 – 1/2
2 – 1/2
3 – 1/2
4 - open
5 - open
6 - open
7 -1/2
Dip Switch – 7 / 0 / 1 (it has a z32 afm)
Other 5 dip switches are set to 0.
Also there are two others internally next to the 5 blue ones which are also blue, VR6 and VR7 what do these do, there currently set for 0 could not find anything in the manual.
Cheers,
dave
needs more EMB info:
Jumper settings inside the E-manage:
JP1 Ignition input pullup/pulldown select
1-2 A resistor is pulled down to ground
2-3 A resistor is pulled up the +ve rail
* Use 1-2 when the ECU's driver transistor is connected to ground
* Use 2-3 when the ECU's driver transistor is connected to +ve (5V or 12V will determine JP2's setting)
Supposedly you can see the input voltage in the Main Unit Setting Information window. If it's 0v, use 1-2. If it's 5v or more, use 2-3.
JP2 Ignition output select
1-2 Output resistor connected to +5V
2-3 Output resistor connected to +12V
* This will depend on the ECU ignitor signals output
* JP2 enables the e-manage to duplicate the amplitude of the original signal
JP3 airflow/VTEC output select
1-2 2nd airflow meter
2-3 VTEC
* Even if you don't have a 2nd airflow meter, leave it on 1-2 for non-VTEC applications
JP4 airflow/VTEC input select
1-2 VTEC
2-3 2nd airflow meter
* Even if you don't have a 2nd airflow meter, leave it on 2-3 for non-VTEC applications
* On 1-2, enables pulldown resistor (for use as VTM signal). This is required because the VTM output is inverted with the VTEC out.
JP5/JP6 Sub injector drivers
Jumper off - Disabled
1-2 - Enabled
* Only enable if you're going to control extra injectors with the E-manage
JP7 VTEC
1-2 Non-VTEC
Jumper off - VTEC
* On 1-2, enables pullup resistor (for use as MAF output)
what should jumpers on emanage blue be set to for series 2 rb25det?
my guess would be.
1= 1-2
2 = 2-3
3 = 1-2
4 = ? jumper off (there is only 2 pins)
5 / 6 = jumper off
7 = 1-2
Edited by 32_Dave
The car wont start at all but if i remove the ecu and re install standard it starts but is flooded so fuel is getting in. whats the difference between crank angle and cam angle sensor? it says on the loom for both of these but the numbers on the ecu correspond with the 1 degree and 120 degree crank angle.
  • 1 month later...
There has been good and bad reports about the emanage in the past, Some people have ignition timing irregularities...
Hi guys, there seem to be a lot of people who have used the EMU with success so was hoping someone might be able to help out a Greddy Emanage newb - please bare with me if this turns out to be something silly. I am helping a mate who is running an E-Manage Ultimate in his Honda, neither of us have used one before and hardly anyone in NZ seem to use or know much about them.
The setup process all seemed pretty straight forward, and for the most part it seems to work fine (fuel/timing adjustments seem to work as expected, datalogs look otherwise sensible, after a bit of adjustment to suit the car mostly drives and idles fine despite having 60% bigger injectors/big cams etc) aside from where we get fairly erratic timing on datalogs as the RPM increase, I am sure its not a representation of the factory map. Basically timing jumps back 10+ degrees and rpm seems to drop (even if vehicle speed is static or increasing) within a single log entry once it reaches around 4000rpm. This is felt as a bit of a misfire when driving.
We've replaced potential points of failure in the dizzy and checked for dodgy earths to no avail - and I've just had an from someone who tried to dyno tune their Supra running an EMU last week who is also getting jumpy ignition logs, I've not spoken with him yet but given the EManage is the common factor on something similar I thought I'd see if anyone has encountered the same kind of thing... or more importantly, fixed it?
We are hoping to get it on the dyno next Saturday but am not going to do anything with this issue floating over our heads, so any input would be greatly appreciated :)
Thanks!
  • 7 months later...
Hey guys, long time reader first time poster.
I recently installed some nismo red side feed injectors into my skyline and am having trouble adjusting the latency settings in my emu. I can't get the car to start and run properly and was wondering if someone could shed some light for me as this is becoming tedious.
lol, EMU's are tedious fullstop, i spend alot of time fixing up screwed EMU tunes...
you should be able just to input the injector size correction and fine tune the latency from there.
when i exported the tune from the emu it had 280cc (seems wrong) and 0ms latency in the settings, I changed that value to 370 and put in 740 and .2 for the latency, but she won't fire up, just cranks....
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
