Has anyone wired one of these into a CA? I'm reading the install guide and I can see it says if you're using low impedance injectors, which CAs and R32 GT-Rs are by default, that you will need a dropping resistor, is that right? I thought the dropping resister was only needed if you were putting high impendance injectors into a low impedance car?
Or is the resistor needed for the Emanage's benefit?
  • Replies 765
I don't have the emu, was looking at a cheap one.
A remap isn't available locally and if I'm driving 6hrs return to get a tune I'd rather it be on something that allows me to adjust it later or at least do data logging.
I know I can buy a Nistune but the emu was much cheaper (yes I realise they are two different devices).
Trying to avoid forking out $440 for a new nistune and software. I have an SAFC2 and just need some timing control (yes I realise everything is better than an SAFC) but as it's a track car it only needs to perform properly at WOT, which at the moment it more or less does.
  • 1 year later...
I know it looks like this thread is dead, but I was hoping there might be someone on here that can give me some feedback, well here goes, if anybody is out there.
I've read through this thread searching for a possible solution for a problem I'm having. Car ran fine before installation. Issues I'm having at the moment are, 1st since installing emu, car is hard to start, wants to flood. I have to open the throttle to get it to start. I have since then cut 20% fuel in the lower coolant temp enrichment tables to get it to start without throttle input, but it is still momentarily rich for about 20 seconds, then leans out to be normal. 2nd, when I try to advance igniton timing, it goes all wacky in the areas I add timing. In the logs, it is really fuzzy, with crazy spikes anywhere from 10 to 40 degrees advance, when in the map I have .5 degree advance. 3rd, I can't seem to get the engine anti stall to work for nothing, maybe the other problems I'm having are associated to this also though. I have double checked the ignition firing order and it is wired up according to the top of this thread. Any help would be greatly appreciated!!
  • 5 months later...
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
