interesting, i stand corrected then... from what a fair few ppl told me the cost/gain ratio wasnt worth it but ill look into it... so how much are we looking at here to get an rb26 head ported?
A basic tidy up certainly isnt going to hurt thats for sure.
SK prices are pretty much there, you might be able to get to around 1k. It really depends on what needs to be done, and what does not
dont trust the bogan shops up here with it..
also i dont think anyone up here actualy does porting
yeah there are some dodge dyno shops up there for sure, i can remember my last training trip up there.
What a ported head should look like ----> http://www.skylinesaustralia.com/forums/in...howtopic=161673
Looks like a half port job to me.... You havent actually taken anything out which causes the majority of restriction. As soon as you get to the divider, this is where material comes out all the way to the valve seat. Inbetween those you have to determine how much material comes out for best flow according to the expected chacteristics of the inlet/exhaust pressure and velocity. I know the inlet looks like its nicely ported (no close up pics, hard to tell) but the exhaust, where the majority of the restriction is on an rb26 is as I said in my opening sentence.
Maybe SK will post a nice example of a ported head and if he doesnt, I wouldnt blame him. A lot of work is gone into finding out where to take material out for the best final port. Its not just remove 2mm all round.
Edited by 180bfj20det
Care to elaborate with specific facts? I take it you are quite familiar with RB head design and port flow, and know both what you are talking about with regards to RB heads and SK's henchmans capabilities.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
