Are you interested in a custom modified PFC to suit your RB20 and RB25?
336 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hey, man, that's a awesome idea, i m into 1 too. Some how im in new zealand auckland, do u mind send it to meif i pay for the postage ? do i just need to buy a brand new set of ECU and hand controller for RB26 , does it have to be R33 or R32 ?
cheers cant wait for your result
if we buy the loom from you, do we have to give you the FC's we get to change around settings? im a little confused...
i would be getting it tuned by trent (autobarn trader on ns.com) you know the road tunes...
cheers
Simon
I heard the Apexi pfc are not available for auto's but have to be modded or programmed to suit is this true??
R33 PFC works fairly well on auto, i have tuned about 4 now, not perfect but most dont notice the small short comings.
Well I can tell you, if this works out good, I'll definately start spreading the word from RS Performance (my business) for all those up here in the States who want a PFC for a RB20 and 25... Myself included.
Edited by Draconis
don't worry Paul, about a 1/3 of people won't front with the coin at crunch time >_<
normally i'd agree. but seriously.. its the god of tuning for skylines (ssh those who think its not the best for $) .. make it happen or we riot your ass....just kidding :mellow:.
If im too impatient Paul I will get a Greddy emanage Ultimate... but as I am now saving for rims. My first 1,500 or whatever the feck its gonna cost me for you to get this working will go to you when the timing is right. make it happen.
Paul - I am a big fan of your work (your Power FC FAQ has been of great help to individual tuners and workshops alike), AND this thread - an affordable Power FC solution for HCR32 owners has always been a hole in Apex's range - and not to mention loss of the ECR33 unit. Air temp is a pretty exciting addition too...
I believe Australian skyline owners acceptance of power FC as such a benchmark tuning tool is in no small part assisted by you. Going out of your way to help educate and support others on an item that otherwise had not a great deal of "freely available" tech info (certianly in english anyway).
Will be watching this thread with great interest. More power to you!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
