heard a rumor that the vq30det turbo will swap over to Rb20/25det with no problems. im just trying to confirm this because i cant read japanese all that well and cant even really find any info on it. just looking to upgrade for cheap
https://www.sau.com.au/forums/topic/161531-y33-vq30det-turbo-to-rb2025det/
Funny you should mention that, I've been looking at this engine for some time. From the looks of it yes the turbo will fit (T3 flange) you'll need to get some sort of elbow made up though.
The exhaust housing doesn't look too big, so not sure if it would really be much of a benefit on an RB25, and it will most likely have a nylon compressor wheel if you get a new one from the VQ30DET Neo
Yes the do fit with little modification. you will need to get the inlet pipe for your intercooler streched or get a new pipe as the the VG30 turbo has a 3" outlet compared to the stock skyline one which is 2.5". they are a great upgrade on the RB20 though . But as far as bot up pattern and flange they are identical to the stock.
be careful Vex typed vg30 NOT V Q 30 so not sure if he's right there as they are very different turbo's.
here is some for sale
http://www.vq30det.com/phpbb/viewtopic.php?t=40
and some dicussion about the idea
http://www.vq30det.com/phpbb/viewtopic.php?t=29
still meaning to get two and have a crack at it :nyaanyaa:
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
