i had my mechanic send my calipers away to be rebuilt...
not the cheapest thing to do, but braking inspires much much more confidence.
it'd be better to ask for one specific to the r33gtst, cant hurt to ask whoever.
i think you can get a rebuild kit from nissan (dont know what it includes but)...
mine have been:
- completely disassembled, cleaned
- pistons replaced
- re-sleeved
- rubber boot/seals replaced
- nipples and banjo bolts replaced
- re-assembled
after a bit more searching found this helpful thread
http://www.skylinesaustralia.com/forums/in...erhaul&st=0
called around few ABS stores
1) SJ6070 part number some stores list some dont...
2) the stores that do list them say its only for one side >_< however according to the thread above its per axle
3) the cost for the kit is $53 inc gst delivered, so the same price since yrs ago which is good to know
guess ill just order one and find out if its for the axle or not...
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
