OEM 1997( built 1996 dec) 180sx type x JDM WHITE BLACK TOP SR20 DET
with orginal 51000k's on clock atm....full service no Repair or Repaint inside out
all modify parts got receipt from Mu's secret (nsw)
THIS CAR IS ALL SET UP FOR TRACK OR DRIFT OR DRAG.......ANY ONE PALNNING TO DO UP ONE HERE IS ONE READY TO GO
parts in the car:
APEXI POWER FC (with hand control)
APEXI (pen style) TURBO TIMER
APEXI RSM (black limited)
DEFI GAUGES X4 (boost/oil tem/water tem/ oil presure)
DEFI CONTROL UNIT
CENTER DEFI 3 GAUGES HOLDER
HYBRID BOOST CONTROLER
HYBRID FRONT MOUNT INCOOLER WITH PIPING
HKS POT FILTER
TRUST BOV
TEIN FLEX SUSPENSION
TEIN EDFC SUSPENSION CONTROL
NISMO SHIFT KNOB
BRIDE SEAT X2 (black)
CUSCO SWAP BAR/CONTROL ARM/STUB BRACE FRONT AND REAR
HKS GT-SS TURBO BRAND NEW (jsut install never boost over 0.9 bar)
NISMO INJECTOR (just bought havent install planning to tune with powerfc)
NISMO FUEL PUMP
S15 5 STUD CONVERSION (front)/R32 5 STUD CONVERSION (rear)
SSR TYPE C 17" with S-03 TYRES
TRUST OIL COOLER
HKS FRONT PIPE/HKS DUMP PIPE
FGK SUPPER LEGISTER R CAT BACK EXCHAUST
PROJECT Mu's FRONT DISK/PADS
6000 K HID CONVERSION
SLEEPY EYE CONTROLLER
ENGINE START BUTTON
2 WAY ARLAM SYSTEM
THIS IS ONE OF THE BEST AROUND IN THE STATES....WONT REGRET IN BUYING THIS UNIQUE 180 TYPE X
ORGINAL WHITE PAINT...NEVER RESPRAY SINCE F.O.B
EXCELLENT CONDITION INSIDE OUT
NO ACCIDENT HISTORY FROM JAP / IN AUSTRALIA
WELL LOOK AFTER JUST SERVICE 1000K'S AGO
NO TRACKDAY OR DRAG SINCE ALL PARTS INSTALL.....
INSPECTION WELCOME
ASKING $22500......(with 1 yr rego)
SERIOUS BUYER WELCOME
P.S interest in a swap for R34 GT-T 4 DOOR or EVO 6 / EVO 6.5
CONTACT ME 0438222228 OR E-MAIL [email protected] or PM me for more details
comeon guys....this is one of the cleanest 180sx type x in the market with all brand new parts never race....
it isd worth for money.....bump!!
  • 1 month later...
  • 3 months later...
  • 3 weeks later...
bump!!!!!!
still in the market .... got offer but not wht i am looking for .....
this car got all good stuff ..... price ONO!!!!!!
sorry for the late reply....will take more pics as request ....
ardie: yr offer is good ....but becoz of having a baby soon.... so ..... not interested in swaping a 2 door car at this stage ......
How about I dispose of the kid when it arrives? Then everyones a winner!
PS just remember 33s are the whales of the nissan performance car family, plenty of interior room for midgets and kids alike
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
