Hey guys,
I've got a R33 GTS (RB25DE - non turbo) series 1 stock, and a couple of days ago while i was driving it the engine just switched off. The CD, lights were still on but the engine died. I just stopped and restarted the engine and it was fine. But the next day it got worst and worst and now after a few minutes (if im lucky), the engine just cuts out. I can still restart the engine but it doesnt last for long. :P
I have been searching the forum and yes, there are a lot of topics similar but none exactly the same with a clear answer to the problem. I'm thinkin it could be the ignition coils?!?
Can anyone help????
Thanks Guys! :kiss:
https://www.sau.com.au/forums/topic/161588-engine-dies/
hmm i would have said originally that your alternator might be screwed but the fact that your cd player and stuff still works i would say no. Change your fuel filter... when it turns off does it splutter before hand or just stop dead cold. also does your car have an immobiliser ???
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3001960
immobiliser would also cust the reds or wouldnt let u start the car again
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3001992
Initally when it turned off it was very smooth and quick. But now its a little slower now, as if the battery has been disconnected. I have checkd da battery and replaced it with a new one coz da old one was almost dead.
Yea, i dont think it would be my immobiliser coz i can still start it up. My car has done a few K's (200,000k +) and to date it has never had any trouble, very reliable. When i restart it, it starts up normally as if nothing is wrong - of course until it dies again
thanks
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3002011
Got a good workshop mechanic you trust?
Take it to him ASAP - well, first thing monday morning :kiss:
I have a feeling fuelling system as said before, get him to check from start to finish.
So when you kickit over - does it stutter for a bit or kick right over like normal?
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3002059
yea thanks man, i thnk i will give him da car tomorrow.
When i kick it over it just starts like normal. The car drives normal too. The only thing is it switches off every x minutes. So you dont think its da coils?
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3002077
It could be, although Im no mechanic! :glare:
Just from what you were saying, it runs, then dies, but all your other power works - stereo etc - so yeah, my first thoughts is somewhere in fuelling system/lines.
How long does it run for once you restart it? few minutes?
Have you noticed any difference to how the car runs of lately? sluggish?Struggles to rev?
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3002105
Thanks guys :glare:
You've cleared up a lot of confusion. I also thought that if it was the coils then my car would be running less cylinders and sounding like shit. But i wasnt really sure to be honest..... The fuel system sounds more realistic.
If anyone else has had a similar problem and have fixed it, let us kno
Cheers boys, appreciate it
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3002479
update mate?
hey guys,
took da car for a drive yesterday, and b4 i started it up i unplugged da ignition module to check for any bent pins or loose connections etc. Anyway, it looked fine and then i plugged it back it (both connections) making sure it was plugged in all da way and not loose.
I drove it to my mechanic but there was nothing wrong with the car. it was FINE!! no more cutting out, no more troubles!! i told my mechanic and he sprayed some silicon in the terminal connectors and then we left it running for ages, not a single problem! took it for a spin and it was da same, no probs
So i guess it might have been a dirty or loose connection or something. Im gonna keep driving this weekend to make sure that that was the problem. Hopefully it is. But if it is the Ignition Module, then at least its gonna be easy for me to change it!
I will keep ya updated!
Thanks guys :P
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3004136
hey guys,
Thanks guys :P
Hey mate, this sounds exactaly the same as my brothers car as i mentioned above about the fuel pump... It was towed to the mechanic and he said he started it, and had to let it run for a while before evetually the pump died again... so maybe its the same, looks like it may be on its last life...
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3004570
FARK!!! i was driving today and i everything was good for da first trip (10 minutes), but after i drove back home it cut out on me and died at the lights. I started it back up and drove home. I then checkd da connections etc on the ignition module but no change. I let it run for 5 minutes without any problems and then took it for a 20 minute drive. As i was almost home it died on me again as i was breaking at the lights. Once again i started it up and drove it home.
I then drove it to dinner about 3 hrs later, where it was fine, but after dinner on the way home it started to drive like it had no petrol. The jerking of the car was giving me the shits. after about 5 minutes it went away and i was able to get it home safetly. I called my mechanic and he still thinks its the Ignition module, he said if its farking up it will cause no sparks and therefore that jerking (no petrol) drive.
Hey man, did your brother experience this?! I hope its just da module. How much did it cost for your bro to fix da fuel pump?! THanks
https://www.sau.com.au/forums/topic/161588-engine-dies/#findComment-3005243
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
