im really contimplating about buying these injectors. i want to know if anyone has run them in their r33's cause i want to buy them but i dont know much about them. If anyone has had them can you let me know how good they are and if there worth buying? there going in my rb25det.
cheers guys/gals :glare:
https://www.sau.com.au/forums/topic/161606-deatschwerks-injectors-555cc/
Just wandering if anybody has pictures or could tell me how neat and symetrical the spray holes are? Having blown money on AVO crap I don`t want to do it again.Are they 4 hole still?
quite a few people have had alot of problems with these. mis matched pressure, going wide and hydro-locking the motor. these are commonly reffered to as "deathwerks" on Ziptied. when it comes to something as important as this i recommend just shelling out the cash for quality and that well known name on the box.
Care to substantiate that claim with some evidence, rather than hearsay?.....
I haven't heard any bad reports and mine have been working fine for 3 months, as have many other for much longer.
i assume these are just high flowed stockies based on the above cylinder filling comment? as the last post link above is missing.... i cant figure out why it would do it otherwise?
Edited by URAS
yeah, they are trent. they modify the pintle to give more flow for a given opening time.
personally I wouldn't use any type of modified second hand injectors. even modified brand new ones is questionable. you can get a set of sard injectors very cheaply which to me makes these high flowed ones a waste of time and money. especially if you have a big $$ motor.
My 550s from them failed, 2 of them stuck open and flooded my motor. Put new ones in and it runs just fine...
everyone always has GREAT success with the DEATHWORKS injectors...but no one really runs the 750 top feeds from them either...they are always using the 550 sides...so maybe that has something to do with it.
my tuner was explaining how the deatsch werks injectors work...basically they use a bigger rod with a bigger opening inside the injector, but theres a magnetic coil that goes around the injector...and becuase they are stock remanufactured injectors they use LESS coil around that rod now and it cant handle the stress of the duty cycle we were trying to run them at. so the coil compressed so much it couldnt close the injector or something along those lines...im not really sure...either way david from deatsch werks is an awesome guy and i still recommend the smaller injectors i know flybert is running them and has no problems what so ever.
BOTTOM LINE:
All those injectors are garabge. Its a friggin KA junkyard injector that some tool could have very well removed from the fuel rail by smahing it on the adjacent car in said junkyard.
they are "rebuilt" used injectors.
they never flow evenly.
and ive heard and experienced numerous failures in countless different ways with them.
ive never had good luck with those injecotors. they never work with rom tunes, they idle like shit. customers bring them all the time and i warn them. we can never get a smooth tune on the dyno with them.
oh and if you take 7 months to look at your product and decide to return it then youre assed out. even walmart wouldnt take that as a return. at least he'll exchange the product for you. that is fair enough.
I HAD f**kING THOSE PIECE OF TRASH INJECTORS LOCK OPEN ON A FULL THROTTLE RUN AND DESTROY A 0 MILE FULLY BUILT MOTOR.
out 5 f**king grand. is that my fault???? you know what he told me?
"well i dont know you can send them back and ill tell you if they're bad."
yes they were free. yes they were sponsored. dave was cool until they self destructed and then it was end communicatoin.
you know what i did? i took each one and smashed them with a hammer. yeah like ill ever buy/support those stupid things.
now was any of that my fault????? NO.
this was just a quick search of ziptied. both Brian W and Cullen onw tuning shops.
Ahh cool, i have done this abit and it works "OK" and the only reason i have done it was to get out of a bind and the machine is at my disposal 24/7, i certainly wouldnt do it on a big $$$ setup, for the same reason i wont use chinese coolers.
If you dont have the cash and are stuck there are plenty of local guys here that do it for next to nothing so why would you pay that much anyway? CREATD motorsport in melb will do em change over for what i consider damn cheap.
Edited by URAS
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
