im really contimplating about buying these injectors. i want to know if anyone has run them in their r33's cause i want to buy them but i dont know much about them. If anyone has had them can you let me know how good they are and if there worth buying? there going in my rb25det.
cheers guys/gals :glare:
https://www.sau.com.au/forums/topic/161606-deatschwerks-injectors-555cc/
Just wandering if anybody has pictures or could tell me how neat and symetrical the spray holes are? Having blown money on AVO crap I don`t want to do it again.Are they 4 hole still?
quite a few people have had alot of problems with these. mis matched pressure, going wide and hydro-locking the motor. these are commonly reffered to as "deathwerks" on Ziptied. when it comes to something as important as this i recommend just shelling out the cash for quality and that well known name on the box.
Care to substantiate that claim with some evidence, rather than hearsay?.....
I haven't heard any bad reports and mine have been working fine for 3 months, as have many other for much longer.
i assume these are just high flowed stockies based on the above cylinder filling comment? as the last post link above is missing.... i cant figure out why it would do it otherwise?
Edited by URAS
yeah, they are trent. they modify the pintle to give more flow for a given opening time.
personally I wouldn't use any type of modified second hand injectors. even modified brand new ones is questionable. you can get a set of sard injectors very cheaply which to me makes these high flowed ones a waste of time and money. especially if you have a big $$ motor.
My 550s from them failed, 2 of them stuck open and flooded my motor. Put new ones in and it runs just fine...
everyone always has GREAT success with the DEATHWORKS injectors...but no one really runs the 750 top feeds from them either...they are always using the 550 sides...so maybe that has something to do with it.
my tuner was explaining how the deatsch werks injectors work...basically they use a bigger rod with a bigger opening inside the injector, but theres a magnetic coil that goes around the injector...and becuase they are stock remanufactured injectors they use LESS coil around that rod now and it cant handle the stress of the duty cycle we were trying to run them at. so the coil compressed so much it couldnt close the injector or something along those lines...im not really sure...either way david from deatsch werks is an awesome guy and i still recommend the smaller injectors i know flybert is running them and has no problems what so ever.
BOTTOM LINE:
All those injectors are garabge. Its a friggin KA junkyard injector that some tool could have very well removed from the fuel rail by smahing it on the adjacent car in said junkyard.
they are "rebuilt" used injectors.
they never flow evenly.
and ive heard and experienced numerous failures in countless different ways with them.
ive never had good luck with those injecotors. they never work with rom tunes, they idle like shit. customers bring them all the time and i warn them. we can never get a smooth tune on the dyno with them.
oh and if you take 7 months to look at your product and decide to return it then youre assed out. even walmart wouldnt take that as a return. at least he'll exchange the product for you. that is fair enough.
I HAD f**kING THOSE PIECE OF TRASH INJECTORS LOCK OPEN ON A FULL THROTTLE RUN AND DESTROY A 0 MILE FULLY BUILT MOTOR.
out 5 f**king grand. is that my fault???? you know what he told me?
"well i dont know you can send them back and ill tell you if they're bad."
yes they were free. yes they were sponsored. dave was cool until they self destructed and then it was end communicatoin.
you know what i did? i took each one and smashed them with a hammer. yeah like ill ever buy/support those stupid things.
now was any of that my fault????? NO.
this was just a quick search of ziptied. both Brian W and Cullen onw tuning shops.
Ahh cool, i have done this abit and it works "OK" and the only reason i have done it was to get out of a bind and the machine is at my disposal 24/7, i certainly wouldnt do it on a big $$$ setup, for the same reason i wont use chinese coolers.
If you dont have the cash and are stuck there are plenty of local guys here that do it for next to nothing so why would you pay that much anyway? CREATD motorsport in melb will do em change over for what i consider damn cheap.
Edited by URAS
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
