I have for sale my 93 r33 gtst for sale. Beautiful car, to nice to be just driving to work.
The car has
rb30 block / Arias forged pistons / shotpeened rods / New bushes, bearings, metal head gaket / head port and polish / oil catch can / Garrett gt35/40 turbo / xforce stainless exhaust maniold / 50mm waste gate and screamer / 3" exhaust turbo 2 cat with stainless jasma muffler / custom plenum / hybrid intercooler / turbo smart bov / 600cc injectors / bosch external fuel pump / custom surge tank / hig flow pump / fuel pressure reg /
Wolf 3d management / apexi avcr boost controler / plx air fuel metor with laptop data logging / extra heavu duty 5 uck ceramic clutch / 19" chrome zenetti rims / kyb lowered springs and shocks / Greddy electronic boost guage / greddy turbo timer / TRUST short shift kit and knob
NOS fogger kit and bottle
BIG $$$$$$$$$ spent Car has produced 301 rear kw on 18psi no NOS and will do high 11 pases
Email me with offer and for photos
https://www.sau.com.au/forums/topic/161609-400hp-r33-gtst-21000/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
