hey mate nice ride.. i understand wat u are going thru, trying to sell mine, which is pretty much similar to urs, and it aint easy... even for a price like ur asking :P
hey mate how much you want for your car bro???????
and r u located in syd???
pm me and let me know hey
cheers.
https://www.sau.com.au/forums/topic/161615--/#findComment-3046962
I was the original owner and importer of this car, and can confirm it has had way more than what he's asking spent on it. The Radiator is a Koyo and the manifold is a genuine HKS one - was originally a HKS2835 Pro S kit when i owned the car (made 250rwkw on 1 bar). The exhaust is full Trust system bar the custom dump pipe - HKS wouldn't let the wastegate open properly. It was not sold by autcion and was a private sale in japan. I've got the japanese vehicle report here somewhere if someone is interested.
https://www.sau.com.au/forums/topic/161615--/#findComment-3114341
Thanks for the extra info man.
Looks like I'm getting jerked around too much for this sale so I think I'm going to keep it unless I get what I am asking for it.
I've got Saity's kit to go on it and some gold 18" gt-c' which are going to be here in a week or 2.
https://www.sau.com.au/forums/topic/161615--/#findComment-3116113
Guest
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
