  • Replies 65
There is no such thing as a good kit period. Halogen housings have different optics to xenon housings, so they cannot focus the light properly. End of story. The only option is a retrofit of oem hid into the housing.
I'm guessing that you hvae an r34 gtt? with the xenons that have been converted from compliance?
I forgot the blokes name, but there's someone with a black r34 on here who put a kit converted headlights. The light output was crap, because the kit puts the focal point of the bulb in the wrong spot.
Go oem. r34 headlights aren't that expensive. I've seen them go for $600 for the pair in perfect nic.
hmm how do i get OEM?? I contacted my car dearler.. 1 guy said ok.. and another told me they can't do it (bastard).. it'll cost me 800 bucks and that he'll (the guy who said that it can't be done) ask his 'friend' about it..
is 600 bucks about the price for them to make it OEM R34 xenon headlights for me?
heers
i've seen halogen (4 door/non turbo) assemblies go for $600, but watching what people are finding over in the Slidewize R34 gear thread, low $900's is the lowest i've seen him quote how much a pair of xenons will cost from the yahoo auctions (delivered)
If you look at your lights evil, do you see the word 'Xenon' embossed anywhere?
I'm looking at those Xenon HID kits on eBay, sells for around $200-$600.
Thinking of getting 1 but dunno if it'll fit or not, what's the criteria?
And does any1 know the diff between xenon & bi-xenon ones?
110% gtst - have you read a single thing that was said in this thread? If you had, then obviously, you wouldn't buy it.
nah not really, maybe the 8000k bulb will be less blinding, anyway does the Series I & II both have H1s?
MANWHORE, iv got an r32 gtr and i was really keen on a HID xenon kit but from what iv read they seem to be usless what do you recommend for me, my lighting at night is shit house
Same here... I've sold it by hooking up sum CAT foggies!
ali, check out Ronin's thread.
The projector's with HID kits are passable from what i've heard. Obviously not the best option.
how handy are you with building things, electrics, etc? maybe you can do a retro fit yourself.
hey ali,
The link that gohan posted up is spot on the money. It is the only 'Real' and 'proper' way of doing things.
r32 headlights are renouned for being the crappest lights ever. If you don't want to go the retrofit option, the best light you can get is probably a set of plus 50 bulbs, relayed so that they get the full 13.8 volts (instead of the 10-11 volts they usually get).
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
