no-one really answered this but you can get oem zenon headlight for r33 series 2's. they were only avaliable in the late series 2 models, i had some on the shell i just bought but they were f*ked so i cant use them, got a quote on brand new ones and they are $1300ish each light, and good luck finiding them second hand probably anyone whos got em dun know, and if they doo i wouldnt ever be selling them
Hey man, yeah, those were teh very last of the series 2, i think some people even refer to them as series 3
really hard to find the lights though, I found some but they wanted $1800USD for them :S so screw that, I'd rather spend them on a new car
Also the bonnet is a different shape for the xenon ones, they do look mint though, they are found on most of the later model R33 GTRs but only a few of the GTS25ts :S
  • Replies 65
damn i didnt realise the bonnet was a different shape, mines a gtst but the bonnet is rooted, but so are the headlights so i guess when i put it all back together its going to be standard. i've heard of them called series 3 gtr headlights but i didnt realise these were the same as the gtst ones. you can get them brand new but who wants to pay 2600 for a pair of headlight, i can think of better things to spend my money on
Yeah man 2600 is way way way too much :nyaanyaa:
I reckon get a set of Series 2 headlights if your current ones are smashed
get one or two sets of Bixenon BMW headlights :thumbsup:
retrofit them, then get the pits sanded out of the headlight plastic and you'll be set :rofl:
head over to HIDplanet.com
or GTR.co.uk and find the guy from Abbey Motorsport who did dual xenon conversion on his 33, it looks absolutely mint
Two lights on at normal beam and at high, the shrouds move to the rear of the lense and open up to full beam :)
MANWHORE, the camera probably doesnt do the lights justice as the light is effected by the flash and lens of the camera which adds to the "halo" effect. so they probably arent that bad! plus if they were that bad people wouldnt be able to buy them off the self and install them!
anyway i think they look good!
:whistling:
Just don't crash :)
they are illegal and if you are found with them in your car when you have an accident, the insurance company won't insure you, they'll try blame the crash on the fact that your lights "dazzled" the other driver
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
