Hmmm... I run the standard AFM too and I ping as well!
At high boost, heavy power usage.
My z32 is imminent (thanks to Philip!) and I'm doing a fuel pump (either a 040 or 984 - doubtful whether a 044 is in the cards :P
Sooo... I'll get back to you guys with just the z32 and Bosch.
Injectors, reg. + plenum is some while off for me I afraid.
Mark - you need to get with Northside sometime!
T.
  • Replies 59
Originally posted by INASNT
man just get some 550cc injectors, z32 afm, bosch 044 fuel pump and take the car to a guy that knows how to tune a pfc and make full use of your high flowed turbo!
sounds good on paper.
haha? or just buy the Mines R34...that may fix it for good
i mean common, he is looking for a cheap solution, i suspect?
not to fork out $2500+
I've already got the fuel pump so another one is not needed.
I've also got Inasnt's old blitz BOV in (at last).
I've been too busy to do anything with my car, looks like i'll be busy on the weekend too - gf has an assignment due which i'll be doing. working 6 days + uni assignments = not much time for anything else.
Killer: where can i change the idle? my car is idling at about 600, shouldnt it be closer to 8 or 900?
maj: nope, i havent cleaned the injectors, but a week ago i bought some of that injector cleaner from a car store (just for the hell of it) and poured it in the tank.
Tony: I have a couple of times. I've been to meets/cruises starting at burger king and chatswood.
Mark
Inasnt,
Are you getting your powerFC through Nengun? I got mine a few weeks ago through him and cost me $1600 delivered. I put it in myself and then (as you know) got it tuned last saturday.
What do 550cc injectors cost to buy + install? I'm thinking of ruling out other stuff that could be wrong before spending more money. I guess ive spent about $10k sofar since I bought it less than a year ago.
What I dont understand is - why would the commander report that the injectors are at 72%. If there is a problem with my injectors wouldnt it read close to 100%?
Majanal,
I like to do things properly so I might have to get another AFM and injectors after I rule out other possible causes.
Mark
Guest INASNT
MRK25T
yep getting pfc through nengun for a bit cheaper than what u paid as its a second hand pfc and new handcontroller!
As for injectors the cheapest i have found is around $170 each for sard ones. I am getting all the parts together (around $7500) and getting it all installed at once.
We can high flow stock R33 injectors to 600-660cc capacity for $150 each. It’s all done on a flow bench and importantly all matched to one another so that all cylinders receive equal distribution. Removal and replacing would be another $200 but I’m sure a lot of you guys are good with the spanners and could do it yourselves :)
Btw, I have heard pinging on the dyno yet the power FC commander only showed a knock value of 27 and the engine check light didn’t come on. Go figure. Also Sydney kid has a valid point with the computer sometimes accessing the wrong load point in the tuning maps. So you might get an anomalous reading once in a while and the car might do funny things.
Guest INASNT
Originally posted by Ustasa
We can high flow stock R33 injectors to 600-660cc capacity for $150 each. It’s all done on a flow bench and importantly all matched to one another so that all cylinders receive equal distribution. Removal and replacing would be another $200 but I’m sure a lot of you guys are good with the spanners and could do it yourselves :(
how long would it take to highflow 6 side feeds?
MRK25T, those dynos look ok to me, nice result acutally. Have you checked your AFM peak voltage yet? The reason I ask is because that is exactly where mine hit 5.1v (max flow) when I first fit and tuned my power fc.
If your car is idling fine at 600 dont worry about it, I think stock is 660 rpm if my memory serves. If it isnt idling correctly, take it back to the guys that tuned it.
If you must mess with it, the idle is in the settings menu. Just remeber you may have to adjust the deceleration fuel cut recovery rpm first (setting above the idle setting), as you have to have at least 100 rpm between it and the idle.
That is exactly what I am talking about! Now if you go into the etc menu (I think) you can disable the check engine light for the AFM. Take the car out again, and see if it still flashes. Alternately, check on your peak hold and it will show you what is maxing out, but I think this is the problem, esp as your injectors are less than 80% and you dont have any noticeable detonation.
5.1v (or 5.115v if you want to be exact) is max flow on the AFM = check engine light flashes.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
