Hey Guys,
I am (with the help of several sponsors) aggressively working to finish our car in time for the USA NOPI 2007 Tour.
As it has been since 2004, the car will once again be featured in the BF Goodrich Tires Booth at select locations nationwide.
I'm going to make this the official thread, and will be updating the thread over the next 6-8 weeks while we finish up the car.
Here is the current mod list, and the latest pictures/videos will be posted soon.
1998 RB26DETT 240SX
Weight: 2950 lb. (w/o driver)
Redline: 9000 RPM
Motor: R33 RB26DETT w/ Ford C4 Tranny w/ Transbrake and GearVendors OverDrive Setup
Cams: Tomei Poncams 260/260 Duration 9.15 Lift w/ Adjustable Cam Gears, Ferrea Springs, Retainers, Locks, and Locators
Pistons: JE 86.5 w/ Hi Performance Upgraded Rings, coated by Calico Coatings
Turbo Setup: Garrett GT4088R (.95 A/R) with Greddy T4 Divided Manifold
Wastegate: Tial 60mm
Intake: Custom
LSD: Cusco RS 1.5 way LSD
Rods: Eagle Rods w/ ARP Rod Bolts
Injectors: Precision 1000cc x6, Greddy 11.0 mm fuel rail
Oil Pump: Tomei
Water Pump: Nismo
Timing Belt: Greddy
Headgasket: Tomei 1.2mm
Headstuds: ARP
Main Studs: ARP
Bearings: Calico
Damper: ATI Super Damper (600-1000 HP Model)
Downpipe: Custom
Mount Kit: McKinney Motor and Transmission Mounts, Custom Driveshaft
Strut Bar: Cusco 40D 40mm Aluminum Strut Bar
Gauges: Autometer Cobalt Series (Boost, Water Temp, Oil Pressure, EGT, Trans Temp, Air/Fuel, 5" Tachometer)
Exhaust: Apexi Ex Mag 3.75" Exhaust
Cooling fans: Permacool (2) 12" High Perf. Electric Pull Fans, 3000 CFM
Intercooler: XS Engineering 24x12x3 core with 3†piping
Blow off Valve: Apexi Racing Max Power
Fuel system: Aeromotive FPR, Walbro 255/lph Intank Fuel Pumps x2, -8 feed line, -6 return line
Engine Management: AEM with 3.5 Bar Map Sensor and AEM Wideband Sensor
Boost Control: Apexi AVC-R
Suspension: Apexi N1 V-Spec Drag Coilovers, Battle Version Rear Upper Control Arms, Rear Toe Links, Rear Traction Links, Front Tension Rods
Axles: Mazworx Drag Axles
Brakes: Underground 300ZX Calipers/ Supra TT Rotors Brake Upgrade (Front)
Stillen Supra TT Rotors (Front), Stillen 300ZX TT Rotors (Rear)
Stillen 300ZX Racing Brake Pads (Front and Rear)
PDM Racing Conversion Brake Lines (Front and Rear)
Wheels: Motegi Prototypes 18x9 (3" lip) , 18x10 (3.5"lip) Gunmetal w/polished lip
Tires: BF Goodrich (Front) 225-40-18 KD, (Rear) 285-30-18 KD
Paint: House of Kolor PBC-36 TruBlue Pearl
Aero Kit: Cwings Carbon Fiber Body, OEM S15 Headlights/ Inner Cirlce S15 Front End Conversion
These Photos were taken 2/2007, this is part of the Stage 2 buildup.
Edited by underground
  • 5 weeks later...
I wanted to post some pics of the build on my car to show it's progress level.
I had to order custom motor mounts for the car, and they should be here sometime later this week.
Right now, it appears like the car is 2-3 weeks from being completed.
It would be much sooner, but I am still waiting on parts to arrive from Japan.
Yesterday, Andy at Southern Imports in Murfreesboro, TN (Mechanic on Project 240SX) installed the Mazworx Axles w/Hubs (http://www.mazworx.com) and SPL Pro Aluminum Subframe Fushings. (www.splparts.com)
A little brake cleaner and some black spray paint really improved the look of the spindles.
As you probably notice, the threads on the hubs are extended for use with aftermarket drag wheels.
this looks great! Ive seen a bit of FULLRACE's RB26 powered S14 Series 1. This sounds like a bit of a contender. :nyaanyaa:
We are both now using the GT4088R, so it would be an interesting matchup.
Yesterday, Andy (Southern Imports in Murfreesboro, TN) began finishing out the fuel system, which should be done today.
Up Next was the Exedy Triple Disc Clutch, special thanks to the team at Exedy for their support over the years.
Ran the -10 AN Lines from Desynz Motorsports Oil Return Mod from the back of the head to the oilpan, as seen in the following two photos.
Finished the lines to the cooler, so that mission is completed.
A shot of the finished oil cooler assembly:
McKinney Motorsports Race Motor Mount Kit, Tranny Mount, and Driveshaft
Everything on the bottom fitted up nice and snug:
Step-by-step Photo Guide:
Greddy RB26DETT manifold, adapted to run twin-scroll and the Tial Sport 60mm wastegate.
The wastegate had to be moved to fit into the 240SX engine bay.
  • 3 weeks later...
Monday Night, Andy and I worked til 2 a.m. @ Southern Imports to get the motor running.
When we attached the AEM EMS ECU, it started first crank with the AEM supplied base map.
I was very impressed with how simple the box is to use, and I want to thank Sean Morris for taking my phone call late at night to confirm we had the configurations setup accurately.
We still have lots of work left to be done, and these are, by no means, final images.
As you can see, there are aftermarket gauge sensors that need to be hooked up. The boost controller is not installed, the intake for the turbo still needs to be ordered, downpipe has not been fabricated, and the upper intercooler piping has not been polished.
But the motor runs, and that's a success in itself.
Yesterday, I transported the car to Texas, and will be finishing up the car here.
Once again, thanks to Andy Vaughn @ Southern Imports in Murfreesboro, TN. He, by himself, built 95% of the car that you are fixing to see. He is a amazing fabricator, engine builder, and friend. Thanks again Andy!
Here are the images and the start-up video:
The car just looks incredible. Thanks for posting up progress shots... full respect :) Are you guys anywhere near Austin? I might be heading over there later this year.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
    • After its dried out Penetrol is you friend to treat rust and seal up those seams
