We now have everything finished with the motor minus the installation of the new 24x12x4 intercooler that arrived today.
I want to thanks Matchless Performance (Addison, TX) for the fabrication of the downpipe, which came out better than I would have ever imagined. The welds are amazing, and extremely clean.
Here are the latest images:
While I still have the interior to finish off, here are the completed exterior shots.
This 240SX has been four years in the making, with 30 corporate sponsors on the stage II build.
I want to give a special thanks to Andy Vaughn @ Southern Imports, and Chris Hamilton (tuner) for their work on the vehicle.
You painted the carbon! Well done, like I've said many times already, it just looks amazing, should drive amazingly well, and should attract an amazing amount of attention. Whats next???
Interior, as the interior is bone stock right now.
crazy.... absolutely insane power... drool....
Need I ask what the quater-mile time of this beast is??
I'm shooting for 9 sec 1/4 time slips.
Insane.... absolutely beast-like ... my car is running low 14's and I'm over the moon - but yeah, with the amount of mods and engine work, I would expect nothing less - do you think you reach the magical 8's mark??
  • 2 months later...
Sorry about the delay on posting up dyno numbers, but I have crazy busy and the car has sat for the past few weeks.
I have not added C16 yet, but I did tune the car for E85 Pump Gas. Right now, E85 (106 Octane) is $2.18/gallon at the pump here in Texas, so it's a no-brainer.
As you can see at 25 PSI, the car made 629/490.
I'm decently happy, but will be upgrading probably to a GT42R, as I really want to break 700whp on pump gas.
Also, took the car to be weighed, and I was pleasantly suprised.
With full interior minus a passenger seat, and 3/4 tank of gas, the car came out to 2890 lbs.
Look for a larger turbo, and big power numbers over the next few weeks!
  • 5 months later...
Update:
Wanted to welcome Deatsch Werks to the list of corporate sponsors on the project car.
We went back to the dyno this past weekend with a set of 1600cc DW Injectors, and they performed flawlessly. The car now has plenty of injector for the current setup.
With that being said, the day didn’t end up as we hoped. We maxed out the dual Walbro 255 lph fuel pumps @20 PSI on E85. The car made just over 650whp before we had to call it a day.
I made a call to my friends over at MagnaFuel this afternoon, and they suggested their street friendly, Inline Protuner Series Fuel Pumps. The particular model they suggested is MP-4303 rated at 2000HP in N/A Applications using gasoline. (good for around 1300 HP on E85).
What’s unique about their race pumps is they are E85 compatible, rebuildable, and they don’t require a fuel controller like the Weldon’s. (And various other brands of “race” pumps.) This is a significant cost savings, and makes this pump is fairly “bolt-on” affair in a car with an aftermarket fuel system already installed.
The new fuel pump will be installed in the next two weeks, and I will write a review for those that may be interested in our findings.
We knew three weeks ago the 1000cc injectors and dual walbros were not going to get us to our goal, but I wanted to see how far they could be pushed on the E85….as I know many on here are debating switching over in their own vehicles.
Here’s the latest dyno video, notice the fuel pressure gauge video at the end:
19e0811b-2a5d-41cc-a442-9a47013f8de5.jpgUnderground Motorsports Demo Car1998 RB26DET 240SXMaxing out the dual Walbro 255lph Fuel Pumps at 650whp@20 PSI.Borg Warner S374 Turbo, 1600cc Injectors, E85 Pump Fuel, AEM ECU, etc.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
