Hey all I'm considering getting a Power FC and a set of Adjustable cam gears for my R32 GTR and was wondering what kind of power gain will I get from that. The car currently is making 240 rwkw on 14psi. It has N1 turbo's and cams. Also approx how much would I be paying for the power FC and hand controller.
So the ecu is remapped?
Must be. Sorry havn't really had a chance to have a good play around with the car since I've had it and it's sad cause I've had it for 4 yrs now and done all of 9000km it, So I'm only really going on what the guy I bought it off of told me.
Yer either way.. The PFC is the next step if you want to try keep up with Andrew. :)
I can't wait to get home and check that thing out. I think i'll go ahead and get a Power FC I'd love to get it up around the 300 mark that would keep me happy for a while.
As soon as you see 300rwk's budjet for a new clutch. LOL
power fc is definetly worth it . Go for the jetro if you can. Mine went from 199rwk's to 185rwks with mods, and power fc added and tuned 260rwk's. I make 292rwk's now with 1.1bar with N1 turbos. You should see aleast that power level because I still have standard injectors. good luck.
Sorry not knowing much about these what is the jetro and what are the difference's????
main diff with the D Jetro to std PFC is it uses MAP sensors and removes your AFM
just incase you dont know... MAP = Manifold Absolute Pressure and AFM = Air Flow Meter
RellikZephyr
Edited by RellikZephyr
292rwkw's on standard gtr injectors? do you have a fuel pressure regulator? what dyno was this on?
Edited by mr_rbman
Ash,
They 'should' do it with around 43-45psi base pressure and close to 100% duty. 43.5psi they flow 520cc's & 40psi 480cc's. Well mine did so yours will be no different.
I'm unsure if the GTR's as standard run a slightly higher base fuel pressure.
Did 292rwk's on peter halls dyno. Have seen them do 299rwk's on tilbrooks dyno but was running a bit lean .
As cubes said though , getting very close to full duty. As far as the pressure , unsure.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
