well guys got my 180sx preety stock standard apart from cold airintake 3" exhuat from cat back hasnt been boosted yet etc
now i wanted to ask when i bought the car it feelt good first second gear felt like it pulled hard when boost =)
but after a week or so it didnt feel as it if it was pulling as hard on second gear didnt have the pull when hitting boost =)
do you guys think there is somthing wrong? am i getting used to the power or is it becoz i installed my system sub amp etc and more weight it still feels good on all gear just doosnt have as much of that pull on second gear
next
i will be ugrading my syspension to tien coilovers with maybe some sway bars =)
and putting in my front bar =)
iam allowing about 2500 k for all this =)
and then i got a k to spend =)
what do you guys recon i spend it on mods =) car hasnt been boosted yet. i dont want to mod it up straght away but just want to look at my options and take things slow
i was also planning on putting on a boost guage
but i found these Din slots that for 3 preety sure they are 46mm guages i wouldnt mind putting 3 in there one boost =) and another 2 that will be good to have
any one know where i can get these 46mm guages and from where also what other guages should i put in for my benifit no rice =)
apart from that what do you guys reconmend me doing =) like i said i want my car to be reliable but i wouldnt mind some good mods =)
id rather do things right with moding and be sensible =)
let me know what ya think Cheers +)
https://www.sau.com.au/forums/topic/16167-afew-questions-for-my-new-car/
It's cool to post on here, I think most people are general Nissan performance enthusiasts anyhow? I was gonna buy a Skyline, but ended up with a 200 but still post on here.
Maybe you're just getting used to the power now? Anyway, sounds like a nice ride, post some pics if you have any.
Cheers
If it were me I'd spend the rest of the cash finishing off the exhaust...
- 3" dump pipe
- 3" front
- 3" hi-flow cat.
If u want to keep standard boost for a while, then this will be the bottle neck you should take of first.
$1K should be more than enough, it should cost you around the $500 - $600 mark.
Then go get yourself a decent panel filter (~$100 new)
Then a boost guage
And finally, boost it up a little.
That will keep you smiling for a few weeks.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
