well guys got my 180sx preety stock standard apart from cold airintake 3" exhuat from cat back hasnt been boosted yet etc
now i wanted to ask when i bought the car it feelt good first second gear felt like it pulled hard when boost =)
but after a week or so it didnt feel as it if it was pulling as hard on second gear didnt have the pull when hitting boost =)
do you guys think there is somthing wrong? am i getting used to the power or is it becoz i installed my system sub amp etc and more weight it still feels good on all gear just doosnt have as much of that pull on second gear
next
i will be ugrading my syspension to tien coilovers with maybe some sway bars =)
and putting in my front bar =)
iam allowing about 2500 k for all this =)
and then i got a k to spend =)
what do you guys recon i spend it on mods =) car hasnt been boosted yet. i dont want to mod it up straght away but just want to look at my options and take things slow
i was also planning on putting on a boost guage
but i found these Din slots that for 3 preety sure they are 46mm guages i wouldnt mind putting 3 in there one boost =) and another 2 that will be good to have
any one know where i can get these 46mm guages and from where also what other guages should i put in for my benifit no rice =)
apart from that what do you guys reconmend me doing =) like i said i want my car to be reliable but i wouldnt mind some good mods =)
id rather do things right with moding and be sensible =)
let me know what ya think Cheers +)
https://www.sau.com.au/forums/topic/16167-afew-questions-for-my-new-car/
It's cool to post on here, I think most people are general Nissan performance enthusiasts anyhow? I was gonna buy a Skyline, but ended up with a 200 but still post on here.
Maybe you're just getting used to the power now? Anyway, sounds like a nice ride, post some pics if you have any.
Cheers
If it were me I'd spend the rest of the cash finishing off the exhaust...
- 3" dump pipe
- 3" front
- 3" hi-flow cat.
If u want to keep standard boost for a while, then this will be the bottle neck you should take of first.
$1K should be more than enough, it should cost you around the $500 - $600 mark.
Then go get yourself a decent panel filter (~$100 new)
Then a boost guage
And finally, boost it up a little.
That will keep you smiling for a few weeks.
    • Found the answer: it wont fit without a bit of work- you'd have to change the guards as well
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
