  R31Nismoid said:
which ISP?
perhaps less hops going direct to melb or something?
I'm with www.beagle.com.au apparently they use telstra wholesale which is why i went with them as i literally live 20metres if that from the exchange and when with telstra speed was great but there download limits held me back. When i do the speed test is says i am with ispone wholesale.
Got this result today at like midday:
  • Replies 319
Posted Images
lol is it even worth having net that slow? :blink:
Hrm - your lucky, they aren't quoting anything more than 20,000kbps on their site.
And they are fairly expensive too
Oh... and they cap your upload speed once you go over - thats the mark of a tightass!
At least iinet once your capped still let you hammer the upload ;)
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
