  • Replies 319
Posted Images
Hey! It's Mushmouse and PumpkinPuss, MK2 and 324Four!!!! We goooot a Gorilla for sale.... Magilla Goriiiiilla for sale.... :laugh: hello Wasteland ;)
Ok, is THIS an ok speed for a fibre connection:
Thats what I'm talking about Andrew, I've seen up to 20,000kb/s from So-net 50M ADSL connection ... I was expecting fibre to be like 800,000kb/s or higher... lol
Hikari Fibre seems like it gets better with age... I just did another test:
same with flets
Can you try testing a fibre connection from where you are just to do a comparison? I'm not at all worried about this, it's costing me less than $40/month for the net and phone together, the speed is brilliant, no 'capping' or any of that stuff you get in AU... it's just that I thought fibre would be *alot* better than (ADSL and) what I'm getting atm from a capability point of view.
    • Spotted in NYC! Fresh off the boat too it seems!
    • he bridged the 2 pipes together in 2 spots. Making a H pipe. i'll get a photo and post it tomorrow
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
