Hey guys, I installed a Trust Power Extreme II system on my R33 today, now when I give it a squirt the engine chokes and splutters at 5,000rpm almost on the dot every time in any gear except for first. There is no loss of power except for a bit of hesitation when it splutters. Does anyone have any ideas what could be causing it.
My mods are only 3 inch dump/front pipe, 3inch hi flow cat, 80mm trust exhaust, pod filter and FMIC with the standard solenoid grounded.
I don't have an aftermarket ECU, so does this mean I'll be needing a tune or is it an injectors problem, sparks, coil packs or anything.... It's only happened since I installed the catback, it was fine with the dump and cat done previously.
Any ideas?
https://www.sau.com.au/forums/topic/161717-spluttering-after-exhaust-install/
Well I'd be looking at the coil packs first off. Very common problem, could just be a coincedence that it occured after fitting the exhaust. If the coil packs are the same as the 32's then I'd be pulling them out and checking all the carbon ends/springs. Mine did the same thing a while ago and I found the all the carbon ends had burnt out, replaced them all along with new spark plugs and the problem was fixed. The carbon ends sit on top of the spark plugs, if you pull the ends off the coils they are exposed and can be replaced easily enough. Not expensive either.
I take it this is in an R33 GTST? do you have a boost gauge fitted? what boost is it now hitting with the free-er flowing exhaust and the intake mods?
maybe you're hitting the boost cut on the factory ECU (though unlikely if its not losing power)
Yeah its a GTST.
Boost is hitting around 10 PSI. A boost controller should be arriving on monday, I thought that the boost may be spiking (I couldn't see it when I was driving but 10 PSI isn't far from 12 so it may be the case), but as you said, its probably not that if its not losing power. The boost controller should stop the spiking (if its there), then I'll look to see if its in fact the coilpacks.
Thanks for the suggestions guys. Hopefully its not the coilpacks, as my knowledge is pretty limited when it comes to ignition problems.
Edited by ProphetR33
What type of spark plugs are you using at the moment?? you need to be running a heat range 6 plug with a 0.8mm gap, ngk BCPR6ES is what im using at the moment and they are fine so far, my mods are hks silent power catback, decat pipe, fmic and solenoid grounding mod.
Bigger exhaust means an increase in boost, this means you need a better spark to ignite the mixture. If your coilpacks are shagged then it will cause the misfire, if you have a stock ECU with the extra boost its probably running very rich which also needs a better spark to ignite. A combination of a tune (new ECU, fuel piggyback), better spark plugs gapped to ~.6-8 (if standard coil packs) or .8-1 if you get some splitfires should cure the problem.
Not sure about which sparks I'm running at the moment, I'll crack it open and have a look when I get a chance.
Thanks for all the help guys its much appreciated, when my boost controller arrives I'll just run it on 7 PSI to be safe at the moment, then check the sparks on the weekend.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
