i test drove an r32 today but didn't buy it coz it was pretty f**ked. anyways, the car was a stocker only mod it had was a POD air filter....
i must say i was pretty f**kin surprised at how loud those things spool up :P from 2.5-3000rpms all you hear is SSSSSSSSSS
and now almost a whole day later and i just can't get that sound out of my head i'm obsessed with it. i'm talking about the turbo spool up on an RB20 ofcourse i dont know if sound wise its the same as an RB25 (R33) ?
i am definately buying an RB powered car now ffs the thing only had a pod :P
if anyone has any sound files or something please post it up i cannot get enough of that noise!!!
cheers
https://www.sau.com.au/forums/topic/161725-stock-r32-gtst-with-pod-only/
looked all over youtube there are some good ones but yeah not exactly the noise i'm after...
don't think i'll ever get sick of driving a car that sounds like that lol. i mean i've heard lots of skylines drive by that sound similar but its only when your actually in the car or driving it that you get to attached to it :P
I had a DRIFT pod on mine and the sound was sweet as and pretty loud. couldnt keep it on often on account of the 2 induction mods but dam it sounded sweet. Like that guy said above, it'll save you buying a bov, you wont have to worry about a drop in performance and unlike the venting bov's which only make noise when u back off, with a pod youll get a loud induction noise then an even louder bov noise but in the same tone (as opposed to a quiet whine then a shhhhht). sounds sweet!
haha I have a r32 with apexi pod and stock bov. It's so loud on boost. Love the sound.
I'll try and record my car later tonight if you still after the sound.
I heard the r33 bov is louder than r32 and can be swapped onto the r32 :D
Edit:
Im at uni atm so cant hear sound;
http://youtube.com/watch?v=AazMf9pucx0
Does this vid have the pod sound?
I heard the r33 bov is louder than r32 and can be swapped onto the r32 :dry:
Edit:
yes you should record yours :(
nah that clip doesn't sound anything like it lol.
basically any turbo car will make that induction noise with a pod. my mate had major timing issues (timing belt jumped a tooth) on his CA18 powered 180 and it would spool from 1500rpm. it wouldn't go anywhere (probably would've run about a 30 second 1/4 mile, and i'm not joking), but it sure sounded fast. but some pods won't make any noise. the k&n pods that are bigger at the top than where they clamp onto the intake don't make any spool noise, but you can hear the bov. i had one on my old 180sx and a mate had one on his r33. but soon as you change to a normal pod you can hear it again.
^^ driven a 180sx(sr20) and and an r32 both stock except for a pod. there's a huge difference with the induction/spool/loudness etc. both had the same pod aswell......well they looked the same anyway..
Edited by R-SPEC
I have a 3" turbo back exhaust with high flowed cat and a Simota pod filter on my 32. Otherwise the engine side of thigs are stock. With these I get massive amounts of induction noise and quite a loud bov sound also. If I turn off stereo I can hear bov when i release accelerator at any revs... and at 100km/h there is constant induction sound. I like it!
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
