Well I knew it would happen, and yes it did, sooner than expected (as seems the go with skylines) my clutch is ultra-f**ked.
Just to clarify, clutch slipping through normal driving is clutch failure correct? (IE: revs certainly dont = power anymore and the over present odour.... lol).
I want to know, is the best thing to do buy interstate clutch and then get it fitted here/ do it myself, or is there anywhere in adelaide I can get a clutch for ~550 dollars and then fit it myself/ cheap fitment around.
I'll be looking at a steady 240kw for quite some time and I found a few kits by a seller named "ROGUEPI" off ebay that use exedy parts for modified street/ occasional clutch dumper rb25 for up to 240kw @ 490 odd buckeroos.
Any help would be great, thanks.
https://www.sau.com.au/forums/topic/161728-clutch-gone-bye-bye/
  • Replies 42
go to exedy clutches at hindmarsh. ill try find the address...they will fix you up. Id fit it yourself, its not hard. Ill help you i dont mind, done it heaps and heaps of times. why pay someone to put it in for you and hammer the f*k outta your car. It'll only take one day outta your life.
Bl4ck32 and I had his (rb25t box on the back of his rb30det) box in and out within 2 hours with just axle stands a couple of jacks and a lump of wood.
Its not too difficult providing you have the correct tools, long extension bars etc etc.
BUT.. I think we were just lucky that day the box slid in on its first attempt.
I would recommend Adelaide clutch services at the Corner of South Road and Cormack Rd Wingfield.
They supply Extreme and Exedy clutches and they really know there clutches.
Have a talk to them and barter a little on the price of the clutch as tyou can usually get them down on price a little.
LOL when we changed my clutch took ages cause you need to spin the box 180 to get it out and the longest part was tryin to get it back just wouldnt go in then finally popped. not a job a reccomend without the right tools and a few strong guys.
We had to spin the box close to 90degree's so the starter motor bellhousing lump cleared the floor pan, we had a hydraulic trolley jack under the rear of the box tied up with rope so that it wouldn't slip when spinning the box. Doing that really made it easy to make the box square/level so that it slid in/out easy. To get the box back up we shoved a piece of wood under it levered it up then slid the jack under it then jacked up the box so that it was in the correct position, bit of of a wiggle and slide and pop in it went.
The car had a OS Giken Twin plate, I expected that to make it more difficult as not only do you have to ensure one plate is aligned you have to make damn sure 2 are aligned. :P
Which reminds me.. Damn.. My last rb20t box that smashed third gear, I was meaning to cut the input shaft off it to use as a clutch alignment tool. The plastic ones from the auto store are never as good as the real thing. :P
There used to be a bloke on Marion road right next to Specialty tuning who would do clutch installs for $250-$300.
Which isn't too bad I thought.
The rb25 box in the r32 is a tight fit, and yes u have to spin it as well to clear the starter hump then rotate it to fit it. Cubes and i did it in the 2 hrs he said. I have a clutch align tool (needed for the Os twin plate i have in) and it slipped the box straight in.
yeah if you get boostworx to do your clutch get him to whip out the pedal box and weld it up and you'll never have a problem with it
as for driving in car parks i havnt found a problem with the xtreme clutch that has a 850kg pressure plate
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
