  • Replies 42
yeh i havent found it too be that bad! it seems smooth and stuff but i guess i havent driven with anything else before!! maybe once i get my car off DEFECTT i could let one of u take her for a spin to see what u think? but yeh she seems ok.
thanks for the replies fellas alot of suggestions, im going to go with getting a clutch myself from sliding performance, their prices are good. unless i can find the same one elsewhere.
5puk button clutch kit from SP
seems like a good price, 500 delivered, and plenty for the power I'm hoping to achieve.
Is there anything else I'll need to buy along with the clutch... i JUST changed my f**king oil (gbox) to redline lightweight and its beutiful stuff and i want to still use it as most likely itll still be blue when it comes out.
whats wrong wid you bitches....too scared to get your hands dirty? :P:O
do it yourself and spend the cash you save on a carton of piss to suck back while doin it.
its time consuming but f**k its only nuts and bolts.
button clutches arent that bad.
Edited by Ryanrb25
  dangerman4 said:
while your at it send your 5 speed to sims, and with the money you get buy a 30 pack of draught, then chuck a 25 auto in it and never worry about clutches again...
Just rear tyres due to those seamless first, second third 160km/h+ on the spot no brake burnouts. :unsure:
  Pauly33GTS-t said:
i got quoted 400 dollars for clutch fitment, machined flywheel, rear main seal replacement.
i wouldnt go there then it cost $400 to fit a clutch to my car yours should be about $250-$300 max
im booking mine into kent brake and clutch this week they fitted my last one and did a good job
if you want a quote ring tim on 8445 2055 after 8:30-4:30
The RB25 rear main seals are the same as a RB30. Cheap as chips. Also super easy to replace. A few bolts and its off, then slide on the new.
Machining of the flywheel, I can't remember what thats generally worth.
Either way $100 to machine a flywheel and replace a rear main seal, probably around the mark.
i said the above. did your cost of 250-300 include the rear main seal or the flywheel being machined?
so that means, 300 for cluctch and 100 for flywheel and rear main seal.
yes mine is fitment seal and machining
i went in today to get firm quote $450 fitting and $490 Xtreme HD clutch i just picked up then went and saw Brad Fox
remember pauly mine is AWD takes longer to do and is harder a little thats why i think yours should be alot cheaper than $400
  Pauly33GTS-t said:
is there anywhere in adelaide I can get a clutch for ~550 dollars and then fit it myself/ cheap fitment around.
Any help would be great, thanks.
I know its not of any help....
but I just bought a 2nd hand ORC Ogura Super Single with Cr Mo Flywheel from Terry @ Kansai Automotive for that $$amount :happy:
Top bloke that he is, even drove it down to Nisswreck (who are doing my replacement trans) himself.
Two thumbs up for Nisswreck and their service so far also.
  chops said:
More info please.
Wha happen?
Well, you see....
The noisey box was going to be replaced anyhows.... I was just putting it off for no good reason.
Driving on my way to lunch with Missa on Tues, clutch pedal started getting progressively sloppier and sloppier. Until, nothing at all. Just made it to Mel's work, pulled over and the clutch wouldnt disengage.
All of this = shagged clutch slave cylinder, which leaked all the clutch fluid along my route up fullarton road. I couldnt diengage the clutch once pulled over, nor could I get it out of gear.
can i get soemthing straigth here... my clutch is burnt out, it still driveable, but u need it hit boost for it to grip properly. all im looking at is a clutch replacement right? nothing else unusual is happenin with the car apart from a clutch odour.
Thats right just a simple clutch replacement.
Check out the slave cyl, and pivot ball while your under there.
If your after a slave/master cyl contact All clutch and brake listed in the workshop sticky. The blokes owned an R33 for the past 6years odd and knows what fits what.
For example... Slave cyl for mine was ~$38, master cyl was $75 new.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
